Canvas with forbidden sign indication, enable to edit and/or calibrate
michelgordillo
Observer Observer
michelgordillo
Observer
Observer
In my learning progress, I have tried to insert a canvas in my design. Everything is coming nicely, but I cannot edit the canvas. In the files, at my project canvas, I have got no image and in the left bottom corner of the square, I have a forbidden sign ( red circle with red diagonal). I have tried everything but no luck and no way to find a solution on the web. My Fusion 360 is personal, not for commercial use.
I would appreciate your help
dsouzasujay
Hi @michelgordillo ,
The forbidden Sign is selectable\Unselectable, that should not stop you to edit the Canvas.
You can edit the canvas by
  • Browser, Right click on the canvas, Edit
  • Timeline, Right click on the canvas, Edit
  • If you want to edit the canvas from the UI, then from the browser right click on the canvas select 'selectable\Unselectable'
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
michelgordillo
Observer
Observer
Thank you, but it doesn´t work so far and that way.
dsouzasujay
@michelgordillo ,
Can you attach the design that you have issue editing canvas in Fusion 360?
You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
michelgordillo
Observer
Observer
done 🙂
thnk you
