canvas is black and has no picture since latest update
Icarus123456
Message 1 of 8
Icarus123456
Hi everyone,
Since the latest update, whenever I attach a canvas picture, it is just pure black at 100% and shows no other picture at any other level. Before, it would be the exact picture at 100%, and a 'ghost' image depending on the level of opacity. I've checked all the settings and I cant find anything obvious that I have to do differently.
Hopefully this can be patched quickly, as I rely on using reference materials and going based off them.
Im currently on a 2013 iMac if that helps.
With thanks.
Replies (7)
Message 2 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @Icarus123456
Can you please post a screenshot of what you're seeing, and attach the image you're trying to place here in the forums?
Thanks!
Karina
Message 3 of 8
Icarus123456
Hi there,
Can you please delete this post, as it shows my name, despite me not allowing it in the settings.
Message 4 of 8
Discussion_Admin
You can change your Id when posting by following the instructions on this post
Note you may have to log off and back in prior to the changes taking effect.
Discussion_Admin
Message 5 of 8
Icarus123456
Hi again, I managed to change it, so panic over.
I tried to take a screenshot, but wasn’t able to do so. I had to take a picture of my screen I’m afraid.
Message 6 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @Icarus123456
Are you able to attach the image here on the forums that you're putting into Fusion?
What is the file extension?
Karina
Message 7 of 8
Icarus123456
I’ve changed the file types to be jpeg, and jpg. The same as I used to be able to do.
Message 8 of 8
karina.harper
Autodesk Support
Autodesk Support
@Icarus123456
Hmm, this seems to be working normally for me. Can you attach your log files here?  Those might give us a clue.
Karina
