Fusion 2.0.19440 x86_64
Windows 10 Home 22H2 (19045.4529)
The offset tool has become difficult to use because the canvas entry field prematurely clips its contents.
1) Bring up a sketch
2) Offset a curve
3) The default value comes up as 1.000mm and the field only barely contains this text
4) The text is right aligned for some reason, so when the number inevitably gets bigger, the most significant digits (and sign) are clipped
Ideally the text box should grow to match the value entered, but at the very least, the field should be bigger and the text should be left aligned.
Other tools start with a larger text field (and seem to have different rules for decimal precision).
Is it 8.533? 18.553? -8.533? Hard to say.
