cant upload dwg file drawing template into the drawing template of fusion 360
adam
adam
it displayed a window indicated that this DWG file can't be inserted because it contains one or more blocks or xrefs. Remove these objects and try inserting again, i do not understand what on earth it does mean. can it be resolved? Thanks!
sutherland-
Dear @adam
Have you tried opening the DWG using online viewer?
Autodesk Viewer can be tested to see if the same issue arises.
Best,
Kritzz
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
g-andresen
Take a look at some of the information
günther
ClintBrown3D
Hi @adam
Please have a look at this article that I put together, I think it will help you: https://clintbrown.co.uk/2021/03/10/quick-tip-creating-reusing-dwg-title-blocks/
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
