Cant select profile. BUG
ss717H872X
Observer Observer
ss717H872X
Observer
Observer
Hello, I have the newest update. A profile is clearly lit as if I can interact with it, but it cannot be selected. Sometimes random actions free the ability, like changing a dimension or removing a timeline feature. You likely won't be able to reproduce it without playing around.
This is a bug. I'd advise you to do much better testing. I'm exhausted and against a deadline and it is NOT the user's responsibility to test your builds.
Seth
  • bug
g-andresen
1. This is a known issue.
2. I described it in a screencast in this thread.   > # 8
3. There is a ticket for this. > # 9
4. Until a solution is found, you can work around the problem by either disabling the analysis or (slightly) shifting the cross-section so that the profile is within the visible area of the body.
günther
davebYYPCU
Part Design - I can guess - as I am a hybrid exclusive user.
Easy to reproduce if you have more than one sketch visible, regardless of Analysis status.
Hide all but the sketch to use, the profile is self-selecting.
As soon as there is more than one sketch visible that same profile will not be selectable and will not highlight in the design window when hovering.
Might help...
