cant select holes for bolt contraint in simulation
scastrophotography
scastrophotography
Hello there,
Just as the title says, I have plates that I want to bolt together in the simulation workspace. Some of them I can insert the bolt constraint, they have the bolts in them, and the others will not allow me to select the holes. Why is this?
File attached.
Thanks, Joshua
scastrophotography
These holes were created with the hole tool, not by extruding a sketched circle.
scastrophotography
problem solved, turns out the plate had a 0.008 degree angle to it.
