Cant save anymore online in team
chris.moebus
chris.moebus
I am getting a weird situation on my fusion environment.
Since today I cant save my files anymore, when I am in the team environment and online.
The window opens normally, the save button is blue as expected. But, when I click it, nothing happens. Pressing enter same.
I tested the following things. FYI I am the admin in this team, my members don't have this issue.
  • Save Online - Team environment - don't work
  • Save Offline - Team environment - works
  • Save Offline, then change to online again - Team environment - works (updated the file successfully)
  • Save Online - Private environment - works
  • Save Offline - Private environment - works
This is very weird. I am using Fusion for a long time, but now out of nowhere I am getting this issue.
Would appreciate any help
BR Chris
g-andresen
If you use the German UI this could be the cause.
Temporarily change the default settings to English.
Günther
chris.moebus
Yes this solved the problem. Thank you
This problem occurs for my projects as well since yesterday. It has to have something to do with the language data. I would suggest to switch back to english as Guenther proposed and keep using these settings until Autodesk releases the next update.
