Cant convert large DWG to fusion model
ned.morris89
Message 1 of 11
ned.morris89
I need to get a large DWG into fusion. Its 272mb.
First I tried by just uploading directly to fusion, but it hit the 1hr timeout.
So then I went into A360 and uploaded it to my account successfully. But now when i try to open it in fusion, it keeps timing out. https://a360.co/39Rlxpv
What are my options here.
Ned
Replies (10)
Message 2 of 11
jhackney1972
You could share the A360 upload so other forum users can give it a try.
John Hackney, Retired
Message 3 of 11
jeff_strater
can you describe what is in this DWG?  Is it 3D geometry, a 2D drawing?  Or, something else?  If this is nearly 300MB of 2D data, you will not have much luck.  Fusion will try to load this into a sketch, and that sounds like it will produce a massive sketch that is guaranteed to cause you problems.
Jeff Strater
Engineering Director
Message 4 of 11
ned.morris89
It is a 3d model with LOTS of surfaces. Its a part model of a vehicle.
Here is the link to the model https://a360.co/39Rlxpv
Message 5 of 11
jeff_strater
this may just be too much data for the translators to handle.  Also, translating it will be just the start.  I highly suspect Fusion itself will not work well with this much surface data.  Is there a subset of this design that you can work with?  Sorry not to have a better answer.
Jeff Strater
Message 6 of 11
ned.morris89
Hmm not really. I dont actually need to work with it...I just need to review it, do some measuring etc etc and give feedback to my modeller.
Message 7 of 11
ned.morris89
Would a .step file be better?
Message 8 of 11
jeff_strater
I suspect not.  I think the problem is the sheer size of the data, not the format.  If all you need to do is review it, I would try loading it into viewer.autodesk.com.  I started that, but it is still running.
Jeff Strater
Message 9 of 11
ned.morris89
Trying now. But its been processing for a while now.
Message 10 of 11
ned.morris89
So it loaded the 2d version. But when I click on "3d view" i get a processing failed error
Message 11 of 11
jeff_strater
same here.  Might be worth trying the STEP version, if you do have access to that.  No guarantees, but worth trying.
Jeff Strater
