Cannot upload files anymore
m.britovsek
Message 1 of 37
m.britovsek
Hello all,
as the title says i am getting errors in F360 when saving/uploading files for 3 weeks now.
any insight?
Replies (36)
Message 21 of 37
RajkumarIlanchelian
@m.britovsek @Can you please check if the log file zip that you captured yesterday has the M folder?
The other thing to see is if your home machine has these files?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 22 of 37
m.britovsek
\W.login has only F and Q folders with ._XX extensions, which i believe are the Projects/3D Models.
I will have to Check, but i uninstalled F360 at home hoping it would somehow fix the upload problem.
Hopeful that the files remained.
Did you found out what was the cause of the uploading/saving problem? I think that i started to experience these problem after Autodesk started with the web browser to launch F360.
Message 23 of 37
britovsekmatic128
@RajkumarIlanchelian
*This is my private account.
Found the tool library and also the post processor which also disappeared.
Is there anyway i could recover the latest save from a few projects?
Any insight for what is causing the issue of not uploading/saving??
Message 24 of 37
caio_cordeiroCNV65
I'm also having this issue since at least 2 days ago. Can't update or upload a bunch of files I have, neither can I export them locally when cloud translation is needed. Small files mostly do not have this problem and I can update/upload with ease. Doesn't seem to be a network problem as my colleagues do not have this issue and the Network Diagnostic Test reports no connectivity issues.
A support ticket was open regarding this issue of mine, case number 21669014 for reference. Attached are my Fusion 360 Diagnostic Logs in case it helps.
Message 25 of 37
m.britovsek
@caio_cordeiroCNV65
Any luck on your side? I still cant upload/save
Message 26 of 37
caio_cordeiroCNV65
No luck yet. I remade from scratch the project I couldn't save so I wouldn't lose it (I can save/upload some small files), logged off, uninstalled Fusion, reinstalled, cleared the cache, repaired, reseted... Still didn't solve the issue.
There's still a warning of "Releasing reservation" in the old project and "Cannot close until jobs in progress complete" even after all those steps, which I thought wouldn't be there anymore.
Message 27 of 37
caio_cordeiroCNV65
Update: something I did yesterday must have helped because today I was able to save files I couldn't since last wednesday, with the exception of the first file where I noticed this issue, which still has the "Releasing Reservation" status as shown in my previous message.
I generated a share link to the file that first had this issue, in case people want to check it out: https://a360.co/40OB96r
When I sent it to support last week they said no issues were found with this file in the machine, so I assume it is either my account or my machine, which is why I did all the repairing/reinstalling yesterday.
I tried to upload the 142mb .f3z downloaded from that link and after almost an entire hour it had only succeeded in uploading 4 of the 120 files in it (and those 4 were up seconds after the upload began). For reference, friday I did the same thing and it uploaded 2 of those 120 in about the same time.
I then logged into another account in the same machine, tried to upload the same .f3z with it and it worked with no issues, so I guess the problem is related to my account somehow.
The only thing I can think of right now that might help is to delete the folder of this account in the AppData/Local/Autodesk/Autodesk Fusion 360 in case it's some local cache issue that wasn't deleted in yesterday's steps. I might try that later today, I'll just wait a bit in case I hear something else from support.
Message 28 of 37
m.britovsek
For me it still doesn't Work.
Tried Repairing, uninstalling/installing several times, deleting the F360 folder, uninstalling Autodesk access, Clearing Cache data.
Cant even access my projects...
Message 29 of 37
caio_cordeiroCNV65
I might have good news for you. I spoke with support today and my issue in now fixed. I can upload files again.
So, my theory was that that file with the "Releasing reservation" status has some problem and was clogging the cloud upload queue or something like that. Clearing the cache and repairing Fusion wouldn't solve that because it's a cloud related thing.
Here's the steps that helped me solve my issue: (note: this will cancel any upload you were trying to make, including updated versions not saved yet)
Step 1- Open the "Text Command" box in Fusion 360 (Ctrl+Alt+C or File > View > Show Text Commands)
Step 2- Type Fusion.CancelUploads and press Enter
And that's it. I hope it helps you just as it did to me.
Message 30 of 37
m.britovsek
Thanks for the suggestion @RajkumarIlanchelian but unfortunately that didnt do anything for me.
The strange thing is also when opening new project i get an error that i need the latest F360 version
but when i check for updates it says im running on the latest version.
@RajkumarIlanchelian Am i going to get any real solution/help or i am just going the get ignored????
Message 31 of 37
RajkumarIlanchelian
@m.britovsek we are most certainly going to try to get this solved for you.
1. Regarding the files not opening mentioning that you have an older version. What. Version of Fusion are you on? Do you follow rate with different people on this file? Any chance you have a Fusion insider version installed?
2. On the file upload , I assume the command line text did not work for you? Per your image are you working on a generative design that is causing this problem ?
Autodesk Fusion
Join Fusion Insider
Message 32 of 37
m.britovsek
@RajkumarIlanchelian Thank you for your help.
1. Currently on v.2.0.17954 (updated today, the problem still persists)
- I am the only on on the project. No one else.
- I tried installing it but canceled halfway.(Insider program)
2. The line text command didnt work. it clears the upload queue but the problem is back when i try to save.
-Its an design with a which references a outside component Which might explain the out of date Msg.🤔(the component is in the upload queue.)
Message 33 of 37
RajkumarIlanchelian
@m.britovsek
17954 is the version we deployed today. Would it be possible for you invite me into the project where you are having the issue of opening the file that says that a newer version is needed? (Raj.kumar.ilanchelian@autodesk.com
Regarding the file that is getting stuck it’s possible that it could be the external reference file. Is the reference file in the same project or across a different project?
Autodesk Fusion
Join Fusion Insider
Message 34 of 37
m.britovsek
All in the same project.
I tried to invite you but cant because in dont have admin right even though i made the project and am the only one in it. I also tried to make a separate project to invite you but the problem is again that i cant upload files.😑
Message 35 of 37
RajkumarIlanchelian
@m.britovsek Can you please email the access issue to me directly at raj.kumar.ilanchelian@autodesk.com? This will make it easier for me to add other engineers from our team to see what is happening here with your account.
Autodesk Fusion
Join Fusion Insider
Message 36 of 37
RajkumarIlanchelian
@m.britovsek I used the email ID you provided to me and it does look like you are the admin to the hub. Now I also noticed that you have another account @britovsekmatic128 .
In which account are you seeing that your hub is editor rather than admin. Did you invite your hub to @britovsekmatic128 as an editor? Can you send me the email ID used to register account @britovsekmatic128
Autodesk Fusion
Join Fusion Insider
Message 37 of 37
m.britovsek
@RajkumarIlanchelian ive sent you an email
