Cannot update Fusion 360 to V 2.0.17244
alvin_boone
alvin_boone
Community Visitor
Community Visitor
I cannot get Fusion 360 to update to 2.0.17244, yet alone any of the later Oct updates.  tried several things including restarting Fusion, restarting the computer and the service utility.  All to no avail.  Attached is the log file that Fusion suggests I submit.
thanks
Alvin
RajkumarIlanchelian
@alvin_boone Thank for the logs. The logs shows an issue for which we have an article to trouble shoot.  https://help.autodesk.com/view/RSTR/2023/ENU/?caas=caas/sfdcarticles/sfdcarticles/Installing-Fusion-...
1. Can you try a different connection (say a hotspot from your mobile ) and see if that makes a difference?
2. You can also try to reset your router and see if that helps.
3. You mentioned you tried the service utility - I assume you tried that "Repair Fusion" from there?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
