Cannot stop mouse movement rotating the model
r.moss
Message 1 of 48
r.moss
Fusion 360 has just updated to the latest version.
I have two tabs open, a model and a drawing of it.  I was editing the drawing.  When I clicked back in the model tab and started rotating the model, I found I couldn't stop.  I tried pressing ESC, right-clicking etc - no good, whenever I move the mouse the model spins.  Eventually I closed the tab, without saving; when I re-opened the model the mouse started working OK again.
Replies (47)
Message 41 of 48
topol27
Community Visitor
Community Visitor
The problem is solved if you change the scale on the trackpad when it freezes. It's quick and easier than dragging the cube somewhere.
Message 42 of 48
mtrutsch
Observer
Observer
Thank you for your reply. This may remedy the problem (need to check it when I get a chance), however, this is just a workaround and does not fix the problem. This happens a lot (depending on how much you interact with your model). It would be great if Autodesk could actually fix this.
Message 43 of 48
Phil.E
The Fusion Insider build that will be available for customers in early January 2025 will have a change intended to fix this issue. Your feedback will be great to hear on the Insider Forum.
How to join Fusion Insider
https://feedback.autodesk.com/key/Fusion360Insider
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 44 of 48
daveMSM4A
Observer
Observer
Looking forward to the fix! The fault doesn't break anything, but really bugs the work flow out 🙂
Message 45 of 48
sebastian1_mejia
And it only took a little over 10 years!!!!!
An incredible representation of the product quality and customer care we have all learned comes standard with every purchase!
No other company has ever been capable of demonstrating this much neglect or simply NGAC.
A truly exquisite achievement!
@sebastian1_mejia - this post has been edited due to Community Rules & Etiquette violation
Message 46 of 48
kaspy_net
Community Visitor
Community Visitor
2025 still problem here.
Message 47 of 48
Phil.E
The Fusion Insider build has a change intended to fix this issue. Your feedback will be great to hear on the Insider Forum.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 48 of 48
basilg
Community Visitor
Community Visitor
Thanks this was helpful!
