Cannot stop mouse movement rotating the model
r.moss
Message 1 of 48
r.moss
Fusion 360 has just updated to the latest version.
I have two tabs open, a model and a drawing of it.  I was editing the drawing.  When I clicked back in the model tab and started rotating the model, I found I couldn't stop.  I tried pressing ESC, right-clicking etc - no good, whenever I move the mouse the model spins.  Eventually I closed the tab, without saving; when I re-opened the model the mouse started working OK again.
Replies (47)
Message 2 of 48
r.moss
It's just done it again!
Message 3 of 48
samuelc1600
I have the same problem
1. put mouse over cube in the corner
2. right click on the cube then move the cube around
Message 4 of 48
Bajicoy
I have the same problem, it is a touch screen trigger error, I have a touch pad connected to my computer for sketches and when this glitch happens with fusion I have to turn on my touchpad, hold alt while moving around to stop spinning while moving my mouse cursor, and then release alt and turn off my touchpad.
I'll keep experimenting but there should be some combination of mouse buttons + alt/shift/ctrl/esc to enter and exit and there isn't a consistent solution because this is a bug with fusion.
Message 5 of 48
Same here
Message 6 of 48
I had the same problem. To resolve this, hold a corner of the view cube and drag it inward towards the middle. This solved the problem, at least in my case. To recreate this problem, hold the view cube and drag it outwards toward the edge of the screen.
Message 7 of 48
jpristel
Thanks!  I deal with this issue all the time and pulling the corner of the cube to towards the center of my screen worked!
Message 8 of 48
dirkdiskey
Community Visitor
Community Visitor
THIS IS THE CORRECT ANSWER
Message 9 of 48
adarro7757
Community Visitor
Community Visitor
Thanks that really helped
Message 10 of 48
427042
Community Visitor
Community Visitor
Man, you're my hero. :')
Message 11 of 48
dentben
Community Visitor
Community Visitor
Thanks!
Message 12 of 48
zyuan4
Community Visitor
Community Visitor
you the goat no cap
Message 13 of 48
leonrvs
Hi, This helps but this occurs every 5 minutes it's irritating any fixes?
Message 14 of 48
jmysyf
Community Visitor
Community Visitor
As a beginner, I'm too naive to consider this bug as my lack of understanding of fusion 360. However, it's a real bug! Thx a lot, man. Your anser helps my confidence 🙂
Message 15 of 48
simspacetn
I've had this happen a few times and my solution was to kill the app and re-open it. Your answer is a big time saver. Thanks!
Message 16 of 48
2025082LG8T7
Community Visitor
Community Visitor
I would just drag the cube towards the center.
Message 17 of 48
Pharmcat
Mine does this all the time.  My design just spins around and around out of control. I have to find the cursor and put it on the view cube and pull toward center of screen. Happens about every 5 minutes, very annoying!
Message 18 of 48
Phil.E
For everyone experiencing this behavior:
Do you orbit:
  • Using the view cube (by dragging it).
  • Or by using hotkeys (shift + MMB)
  • Or by using the orbit command icon in the navigation bar (lower center of application)
  • What is your "pan zoom orbit" preference?
  • Do you use a regular mouse or trackpad?
These steps reliably recreate the issue:
  1. Launch Fusion 360
  2. Activate the orbit feature via the mouse button
  3. Before releasing the mouse button, drag the mouse cursor over the browser tree
  4. Release the mouse button
  5. Result: Orbit feature is still active
This step reliably stops the issue:
1. Place mouse pointer on view cube
2. Drag the view cube towards the center of the screen.
(Ref: FUS-82525)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 19 of 48
cjcolyer
Community Visitor
Community Visitor
I have had this issue for ages, thanks for this tip!
Message 20 of 48
celeste_serralta
Observer
Observer
Thank you!
