cannot start
cannot start
Message 1 of 1
cannot start
I also cannot start
I had a MS update
KB4565503
this caused my system to take 10 minutes to boot
looking on the MS issues site they said to update video drivers, so did that no change
I removed the MS update and system now boots normally in 30 secs
tried to start fusion and blue circle and nada, it is in task manager
removed from task manager, reloaded an older nvidia driver and same issue
from the logfile
2020-07-25 15:14:33,719 - MainProcess(10800) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2020-07-25 15:14:33,724 - MainProcess(10800) - MainThread - adsk.dls.streamer - INFO :: # #
2020-07-25 15:14:33,724 - MainProcess(10800) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001DD306A3FC8> #
2020-07-25 15:14:33,724 - MainProcess(10800) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2020-07-25 15:14:33,724 - MainProcess(10800) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\jbole\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2020-07-25 15:14:33,724 - MainProcess(10800) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\jbole\AppData\Local\Autodesk\webdeploy\meta\streamer\20200714104000\resources\buildinfo.json
2020-07-25 15:14:33,728 - MainProcess(10800) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'reconfigure', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'write_through', 'writelines']
2020-07-25 15:14:33,728 - MainProcess(10800) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2020-07-25 15:14:33,728 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20200714104000
2020-07-25 15:14:33,729 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2020-07-25 15:14:33,731 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\jbole\AppData\Local\Autodesk\webdeploy\meta\streamer\20200714104000\resources
2020-07-25 15:14:33,732 - MainProcess(10800) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2020-07-25 15:14:33,733 - MainProcess(10800) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2020-07-25 15:14:33,733 - MainProcess(10800) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2020-07-25 15:14:33,733 - MainProcess(10800) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=True, connection=None, force_full=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000001DD307C99D8>, pipes=None, procfac=<function uninstall_process at 0x000001DD30B42828>, profile=False, pull_dest=None, purge=False, quietmode=True, stream='production', threadscount=5)
2020-07-25 15:14:33,733 - MainProcess(10800) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2020-07-25 15:14:33,733 - MainProcess(10800) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2020-07-25 15:14:33,734 - MainProcess(10800) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2020-07-25 15:14:33,734 - MainProcess(10800) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2020-07-25 15:14:33,734 - MainProcess(10800) - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2020-07-25 15:14:33,739 - MainProcess(10800) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2020-07-25 15:14:33,739 - MainProcess(10800) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2020-07-25 15:14:33,774 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2020-07-25 15:14:33,803 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: Primary app is 73e72ada57b7480280f7a6f4a289729f
2020-07-25 15:14:33,815 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: The session id is 6203bb1c-4648-42cc-9edb-42372c74c84e
2020-07-25 15:14:33,816 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: Configure app begin Cleanup
2020-07-25 15:14:33,816 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: Cleaning up old-version apps, ignoring any apps except for packages belonging to an in-progress app
2020-07-25 15:14:33,844 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: Check app: 73e72ada57b7480280f7a6f4a289729f
2020-07-25 15:14:33,844 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: Check app: 47458aa04dc04be2a184ca4322d75d74
2020-07-25 15:14:33,888 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: Configure app complete Cleanup
2020-07-25 15:14:33,889 - MainProcess(10800) - MainThread - adsk.dls.streamer.process - INFO :: Process Complete in 0.14858127 seconds
2020-07-25 15:14:35,344 - MainProcess(10800) - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2020-07-25 15:14:35,356 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2020-07-25 15:14:35,356 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2020-07-25 15:14:35,356 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2020-07-25 15:14:35,356 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001DD306A3FC8> #
2020-07-25 15:14:35,356 - MainProcess(10800) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
Replies (0)
