cannot slide table top down
happyday.mjohnson
happyday.mjohnson
I have modeled a table top and a wall mount. There are two motions between the wall mount and the table top that occur around the dowel: - a 90 degree revolute motion when the dowel is at the lower end of the slot on the wall mount. - after the 90 degree revolute, a sliding motion such that the dowel now rests on the top part of the slot. I have not been able to figure out how to do both motions around the dowel. How do I do both within Fusion 360? (thank you).
davebYYPCU
Pin Slot Joint,
with Joint limits,
with a motion link if required.
Might help....
jhackney1972
To make this joint you need to introduce a hidden component.  This component will be used to give the slot movement and will also serve as the component to add the table revolve movement.  When you open the attached assembly, you can drag the table if you desire but the best thing to do is right click on the Motion Study, in the Browser, and Edit it.  Then you can run the motion automatically using the play button.  I wish you could slow it down further but that is one of the issues with the Motion Study feature.
John Hackney, Retired
