Cannot save designs that have configurations
alex_winter
Message 1 of 8
alex_winter
I am having a problem saving a design that has a configuration in it. For example, if I try and save this workholding, vice (CAM Samples->WorkHolding->SCHUNK->Vise Clamping->Centric Clamping, Vises->KSC3->SCHUNK-1514256, KSC3, 160-480), when I hit the save as button, I am getting this error. Instead if I try and copy the file I get this error. Any ideas on how to fix this
I have tried exporting it also but it doesn't give me a file.
Replies (7)
Message 2 of 8
Steven_Gao
I tried to save as/export the file and it is working for my side. Did you do some changes of the sample file or just open it and save as to other folder?
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
Message 3 of 8
alex_winter
I just opened it and save as. I have tryed 2 different PC's with fusion installed with different accounts and they have the same issue aswell. I can try re-installing fusion and see if that helps.  It only seams to be if there is a configuration in the design.  I can save non-configurations fine.
Message 4 of 8
alex_winter
I did a uninstall a fusion then restarted the PC. Reinstalled fusion and I am still having the issue.
Message 5 of 8
CGBenner
@alex_winter @Steven_Gao
There is another forum post with this same issue, maybe this post holds some clues?
Chris Benner
Message 6 of 8
alex_winter
thanks I just posted there aswell.
Message 7 of 8
karina.harper
Autodesk Support
Autodesk Support
@alex_winter
We had an issue with Configuration save in certain regions, can you try again?
Cheers,
Karina
Message 8 of 8
CGBenner
@alex_winter
Hi, has this issue now been resolved, or do you still need some help with this one?
Chris Benner
