Cannot ReInstall Fusion360
s3720520
s3720520
Community Visitor
Community Visitor
I am currently unable to install Fusion360. Every time I try to, I am presented with the error screen that cites a problem labelled 'file-data'
I originally uninstalled Fusion because I couldn't install a software update. I tried once to reinstall and it failed, so I deleted all files in the Autodesk and Fusion360 folders in my computer as well as the application scripts themselves. I cannot figure out what the problem is and would appreciate support on this!
I have attached my log file.
dooyoul_chung
@s3720520 Thank you for sharing experience and development is working on address issue.
The reason you experienced this issue is some "dock" icon does not have "file-data" definition. You can find the app "dock" icon with below command line from Terminal .
defaults read com.apple.dock
Then you will have similar data as below. check "file-data" entry and remove 'bundle-identifier" associated icon then try install again.
If you are unsure then send me dock.log file after run below command line
defaults read com.apple.dock > dock.log
Dooyoul.
