Cannot reach the "Post", "Ok" and "Cancel" buttons of the Post Properties process.
weewx02
Observer Observer
weewx02
Observer
Observer
Even I have hidden the Task Bar, but I am still not able to press the buttons since it is over my shown screen.prob.JPG
HughesTooling
For now I'd suggest unchecking this option in preferences and going back to the old post dialog. @seth.madore  Something to look at!
Mark Hughes
Owner, Hughes Tooling
seth.madore
@weewx02 can you give me some info about your computer and display size? Are you running Fusion in full-screen mode, and what is your resolution? What OS are you using, and are your graphics drivers up-to-date?
Seth Madore
serge.quiblier
Hello @weewx02 , @seth.madore
If the display resolution is less than 713 in the vertical direction, it can be the issue.
The smallest size i can resize down to is X800 Y713 approximately.
This can be your issue apparently, can you confirm please.
So we can advise the developper for srinking to  smaller vertical size.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
serge.quiblier
Hello @HughesTooling , @weewx02
With the latest august release the Feature flag has eveolved in a different one.
Previously you have to enable NC program,
nowadays you must, request the older dialog to be used.
Latest 2.0.10813 feature flags.Latest 2.0.10813 feature flags.
Cheers
PS : Capture from Fusion v2.0.10813
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
cam.autodesk.com
serge.quiblier
Hello @weewx02
You may have a similaire issue as this guy in this thread.
It was due to scaling of his display.
so the 1080 /1.50 = 720  which is not that bigger than the dialog at 713.
Regards.
Serge.Q
cam.autodesk.com
