The project I'm working on at the moment has two sketches named "Top guides" and "Bottom guides", respectively, which by mistake ended up in the wrong sub-assembly. In the browser, I've never had any trouble moving sketches around. But, for some reason, in this project I'm working on Fusion 360 won't let me do this, displaying a rather unhelpful warning message with very broken grammar:
I've tried to reproduce the problem on a small project by recreating the browser and timeline structures, but no dice: Fusion 360 is always happy for me to relocate my sketches in the browser in and out of any component, so I'm at a loss.
Here's the project that's causing trouble: http://a360.co/2DRAzKG
My goal is to move sketches "Top guides" and "Bottom guides" from "Encoders" up into "Small parts". To simplify matters and attempt to pin down the cause of the problem, I've deliberately deleted all features after after these sketches in the timeline. Prior to deleting those, neither sketch could be moved up to the parent component in the browser. After deleting, I'm at least able to move "Bottom guides", but when I try to move "Top guides" I get the above error message. I can only assume this is a bug, since these sketches are not explicitly being referenced by anything---how could they when they are the last thing on the timeline? And, in any case, sketches can usually be moved around in the browser.
In fact, I'm really curious about what kind of situation would prevent a sketch from being moved in the browser, because I can't think of one. For example, even if a sketch references and extrude feature to establish its dimensions, it can still be moved around in the browser. This is the first time I've encountered this problem.
Thanks!
