Cannot move multiple selection in drawing
Zbigniew.Krysa
Zbigniew.Krysa
Why I cannot move selection including two text area? Please have a look movie attached.
https://we.tl/t-uWUHsSywwz
Zbigniew Krysa
g-andresen
1. please do not use an external (unknown )portal for uploading, but the direct way (e.g. .mp4) here in the forum.
2. download the AD screencast for such purposes.
günther
ClintBrown3D
Hi @Zbigniew.Krysa
That should be possible, are those regular text objects?
Can you share the dataset  with us to have a look at?
You can attach the F3Z file here, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Zbigniew.Krysa
HI,
I wanted to attached the mp4 file but there some issue here on the forum that "attache button" is visible once per 5 posts - usually cannot add video via forum.
Zbigniew
Zbigniew.Krysa
Yes, there are regular text objects. I sent you link to the file (Fusion Hub) in private message
Zbigniew
ClintBrown3D
Hi @Zbigniew.Krysa
I know what happened here (thanks to @varun.patil) you had selected both sets of text, but used a grip selection, which is like an override. When dragging the grip, only the text attached to the grip will move.
Clint Brown
