Cannot move components into subassembly or group
2x2Designs
2x2Designs
I have searched for literally hours for solutions to this but as 2022, I cannot find one. I see others with the same issue, but no solution. I currently am designing a shed in Fusion and want to group the components, like walls, base, rafters, ect into subassemblies. I have the timeline all the way to right, but when I select a component,  I cannot move it or drag it. I have tried turning off the design history, still the same issue. I have gone into another project to test and it works there. I am just very confused
jeff_strater
likely, you have relationships between the components that are blocking the restructure - that is the usual reason that I am aware of.  I'm not completely sure why it would not work without history enabled.  I'm not sure whether, say, joints between components could block restructure, but that is possible.  If you share the design, it's possible that someone can figure it out.
This is a known limitation in Fusion, and one we would like to address in the future.
Jeff Strater
Engineering Director
