cannot make a offset
piet.debrock
Message 1 of 8
piet.debrock
 when i sketch a rectangle and extrude it and than sketch a rectangle on top of the extruded rectangle than i cannot offset the rectangle
Replies (7)
Message 2 of 8
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 3 of 8
piet.debrock
hi is this what you want?
<iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/02953797-6d7c-4393-96cf-73883a7e30cf" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 4 of 8
g-andresen
The contour you want to offset is not in the current sketch.
 Screencast (1:40)   > 1. project body or sketch contour
                                     2.  create Offset
Screencast
günther
Message 5 of 8
piet.debrock
hi,
thanks for the quick help . Earlier i could hover over the rectangler and the lines turned blue to make a offset.
when i project i also have to project  every single line( a lot of work in complicated sketches).the fact i have to project, is this not because he does not recognise the plane ?
Message 6 of 8
g-andresen
the reason that a projection is required is that the needed profile is not in the active sketch.
günther
Message 7 of 8
piet.debrock
now i understand. I know for you it seems silly but i am verry grateful. Thanks
Message 8 of 8
g-andresen
@piet.debrock  schrieb:
I know for you it seems silly ...
Not at all.
It is precisely through the diversity of experience that the greatest possible number of users will gain know-how.
günther
