As described in the Fusion support threads, clicking the Fusion application results in a short "loading" wheel, and no application ever appears. I can load the app via "Run as Administrator" Mode, but it will hang on the loading screen indefinitely. If I click anywhere on "Run as Administrator", it simply licks up and crashes. The application worked fine just a few days ago. I did install a new 10GbE NIC into my PC which I highly doubt would cause this, but I did remove it, remove the drivers, and unfortunately no luck.
I have tried every possible solution I've seen on the forums, including clean installing, NIC priority in Windows Networking (when I had the 10GbE installed). The PC is up to spec and fully updated.
Specs: AMD 9800 X3D, 48GB DDR5, RTX 4090, NVME Storage. Win Update and Nvidia drivers fully up to date.
Any help to get back to modelling would be much appreciated. This is on the free Non-Commercial version. I have looked at logs, if someone can direct me which the appropriate logs are I can upload them.
