Cannot install Fusion 360
Greetings.
I'm trying to install Fusion 360 on my desktop, too (have it installed and working on my laptop) but with no success.
Configuration:
HP Z820, 128 GB ram, Win 10 Pro 64bit, last updates, Symantec Endpoint Protection. Latest BIOS, too.
Tried everything noted on different treads, disabled Av, Defender, opening ports in firewall, used Fusion 360 cleaner yet still failing.
Shall highly appreciate your assistance.
Thanks in advance and best regards,
Radu
matt.berggren
Hi Radu --
Can I ask you to double check the Proxy settings under Internet Properties->Connection tab->LAN Settings.  If there is a Proxy setup of some sort, can you set this to Automatically Detect Settings and let me know if this solves the issue?
Thank you!
Best regards,
Matt - Autodesk
Hi Matt.
Thanks for your swift reply.
Unable to modify as LAN settings are managed by system administrator. Which, I suppose, is Symantec Endpoint Protection, isn't it?
However, additionally, there's no proxy used.
Matt,
Thanks for your assistance, eventually succeeded to have it being installed. Had to perform several changes, particularly in the group policies, as in regard to the loopback IP.
Thanks anyhow.
A
