Cannot expand two concentric circles
Hi *,
this is probably a very basic user question but I am a bit confused here:
a) I have sketched two concentric circles (left side) - I expanded them in order to get a 3d object - all good.
b) I have created a second pair of concentric circles in the same sketch (right side). I tried to expend but I cannot select the area between the two circles which I would like to expand. It does allow to select the separate lines of the circles - but that is not what I intend to do...
Pls. advice what my issue might be and what I could do to get things solved. Thanks!
Best regards,
Alex
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous
Welcome to the Fusion 360! Heart
It's supposed to extend but I don't get it why. would you mind sharing your design?? Here is how to share your design
I look forward to your reply
Many thanks,
Ahreum.
Hi Ahreum,
thanks for your help!
pls. check the link: http://a360.co/2yamGY7
You will have to download it since I think you cannot see the issue online, since it is in the sketch 😞
In case you need further details to get me startet, pls. don’t hesitate!
Best regards & many thanks,
Alex
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for sharing your file Smiley Happy
However, I was unable to download your file for some reason. It was supposed to show the download button on the right side.
Could you share your design after downloading??
I look forward to your reply Smiley Happy
Many thanks,
Ahreum.
Hey Ahreum,
sorry for the trouble. I hope that I have exported the correct file type?
BTW: I do mean "extrude" not expand 🙂
Best regards,
Alex
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for waiting Smiley Happy
Mm,, I have uploaded your file on my project and it seems that is working well so I suspect of your graphics card or driver.
This is my steps. could you confirm that is correct? http://autode.sk/2ycqHK3
Could you check this option?
1. Graphics driver installed by up to date
2. Limit effect to optimize performance option enables.
Many thanks,
Ahreum.
