Cannot create tool body for loft issue.
jaspebak
jaspebak
I'm going to preface this by saying tat I'm not sure if I am using the correct tool here, but I'm trying to merge from the rectangle face to the cylinder and am unable to do so.
jaspebak
I'm thinking maybe it's because it's a solid object? Should I just go back and attach the circle to a plane and translate that out, to then loft it?
jeff_strater
you are using the right tool, but the way that you have this set up is incorrect.  You are close here:  "Should I just go back and attach the circle to a plane and translate that out, to then loft it?"  Then, you can loft from the rectangular face to a sketched circle:
Screenshot 2023-11-21 at 3.54.57 PM.pngScreenshot 2023-11-21 at 3.55.46 PM.pngScreenshot 2023-11-21 at 3.56.03 PM.png
Jeff Strater
Engineering Director
jaspebak
Just figured it out as you replied too, I really just had a hard time figuring out how to translate the sketch. I really ought to learn from a tutorial vs winging it. Thanks so much for the answer anyways!
