I just started learning, and worked my way through Parts 1, 2 and partway through Part 3 of Lars Christensen's "conduit box" tutorials, but I got stuck on preparing a polygon shape prior to extruding. I'm unable to complete full definition of the 2D polygon sketch, i.e. have it change color from light blue to black. Polygon 1 image attached shows two attempts I made using the methodology used in the tutorial to add the ridges in the box lid by starting with a free form polygon and then making the left and right edges vertical, adding left-right symmetry and adding constraining dimensions.
1) What step am I missing to complete full polygon definition?
2) In the Polygon 2 image, I couldn't complete the polygon perimeter (leading to the lower right polygon in Screenshot 1) by moving from point-to-point in sequence due to the third line segment being constrained horizontally, so I had to restart a new line at the polygon apex and then finish working my way around to the start point. I didn't have this issue constructing the upper-left polygon in the Polygon 1 image, what is different?
3) Also note (see the Polygon 3 image) that I had trouble forcing a dimension from the top of the right edge to the X-axis, as the whole polygon shifted downward instead of "stretching". How should the polygon reference points be selected for proper "stretch" style dimensioning?
I suspect issues 2) and 3) may be coupled to Issue 1). I'm using the free version in Windows 10.
Thank you very much for your help!
