Cannot Archive Project - Permission Denied
d23amtics004
Message 1 of 19
d23amtics004
Hi, I created a empty project named DIY, but when I try to archive it, I get an error saying: "You don't have the required permissions to perform this operation." I'm the creator of the project, so I'm not sure why this is happening. Any help or suggestions would be appreciated!
Replies (18)
Message 2 of 19
RajkumarIlanchelian
@d23amtics004 Any chance that you are on a team hub that you do not own?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 19
d23amtics004
I only have one hub, and the project named DIY is showing under the "Shared with Me" section, even though I’m the one who created it. In the admin panel, it also lists me as the creator. However, I’m unable to create new folders, upload files, or save any changes.
When I try to create a folder, I receive the following error: SEC_WRITE_ACCESS_DENIED - Write access denied. Urn=urn:adsk.wipprod:fs.folder:co.yAG_4nV7TxmMO8vLVX2Cmw
Message 4 of 19
RajkumarIlanchelian
@d23amtics004 Can you DM me your email used to register Fusion?
Autodesk Fusion
Join Fusion Insider
Message 5 of 19
d23amtics004
Sent you a DM.
Message 6 of 19
RajkumarIlanchelian
@porkodi_autodesk Porkodi, any idea on what might be happening here? I will send you the email ID but checking in support, it shows that thy are the admin of the hub.
Autodesk Fusion
Join Fusion Insider
Message 7 of 19
porkodi_autodesk
Hi @d23amtics004 and Raj,
   I have forwarded this to our development team to take a look. We will keep you posted. Thank you for reporting.
Porkodi Nathan
Message 8 of 19
porkodi_autodesk
Hi @d23amtics004
                       Our development team has resolved the issue. Please can you confirm from your end if you are able to archive your project? You should also be able to create folders within your project and archive the project.
Thanks!
Porkodi Nathan
Message 9 of 19
d23amtics004
Yes, I can confirm it’s working now. Thank you!
Message 10 of 19
matthew.nolan1111
@porkodi_autodesk I am having the exact same issue. I sent a DM to @RajkumarIlanchelian and he has forwarded my account information to you. Looking forward to any support you can provide.
Message 11 of 19
porkodi_autodesk
Hi @matthew.nolan1111 ,
Thank you!
Porkodi Nathan
Message 12 of 19
porkodi_autodesk
@matthew.nolan1111
          Our development team is working on resolving your issue. Please can you try  to archive your project once more? Can you DM me your project name as well?
Thank you,
Porkodi Nathan
Message 13 of 19
matthew.nolan1111
Hi @porkodi_autodesk,
Unfortunately, the issue is still persisting. I have sent the project name in a DM.
Message 14 of 19
porkodi_autodesk
Thank you!
Porkodi Nathan
Message 15 of 19
matthew.nolan1111
I am indeed able to archive the project now. Thanks for your help!
Message 16 of 19
ChessieFan
Observer
Observer
@porkodi_autodesk I am also having the same issue and have sent a PM.
Message 17 of 19
porkodi_autodesk
Hi @ChessieFan
Thank you!
Porkodi Nathan
Message 18 of 19
porkodi_autodesk
Hi @ChessieFan ,
Thank you!
Porkodi Nathan
Message 19 of 19
ChessieFan
Observer
Observer
Thank you! I was able to archive and delete the project.
