Can you make dimensions equal with a sketch or between features?
howardwstolz
Observer Observer
howardwstolz
Observer
Observer
Is it possible to make two dimension equal in a sketch or between separate features on the history tree?
Other cad systems I've used allows dimensions to be related (equal or even using an equation).  Can 360 do that and if so, how?
jeff_strater
There are a couple of ways to do this.  In the video below, you can use the dimension in the earlier sketch to set the value in the later sketch.  Or, you can do this using a user parameter.  Create a user parameter, and set both dimensions equal to that user parameter.
(view in My Videos)
Jeff Strater
Engineering Director
g-andresen
Please share a file and explain what goal you are after.
File > Export > save as f3d on local drive > attach to next post.
günther
