Can't work re-anchor on prmitive cylinder command
makitayoshihisa
makitayoshihisa
For example,
when I use cylinder command,
re-anchor doesn't work for hight.
Is it bug or something?
g-andresen
I think everything is as expected.
If it is not, please show it in a screencast
günther
MoshiurRashid
Hi
Thanks for posting. I would suggest you to use Extrude commant to create a cylinder from a circle. It gives you more controls and sustainable way. 🙂
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
makitayoshihisa
Hi
Thank you very much for your reply!
Unfortunately still doesn't work to me...
I attached screencast here!
I want to fix it but I will try again!
Thank you.
makitayoshihisa
Thank you for your reply!
It's good to use Etrude! Nice!
Thank you!
