Hi all!
First off I would like to address that I am very new to designing models. I only just got my first 3D printer last week so I might not know all terms, functions in fusion 360 and so on. Bear with me.
Alright, now to the actual issue.
I’ve been working on a sketch and I need to cut a hole in it. The hole have to be the shape of a rectangle with 2 of the corners in one end chamfered down to -2mm in width and -8mm in length. I thought that I could just design another sketch with the shape and properties that I wanted and then turn that into a hole and put it in the sketch that I wish to cut in, exactly like you can in tinkercad, but this proved to be an issue that I would struggle with for over 3 hours and eventually give up on.
Are there any way for me that I can make such a cut? Are there any way that I can select an entire sketch and use that as a hole?
I’ve attached a picture of what I am trying to model and on that picture you can see the chamfer and cut I’m trying to achieve. In case there’s any doubt, it’s from the chamfered corners and down to the other end of the plate that I’m trying to cut.
