Can't update to the latest design
ss38087VE7M
ss38087VE7M
Community Visitor
Community Visitor
I am new to this auto desk designing and I am trying to update a design that has previously designed components. I am getting error that previous design is not up to date. I am attaching pictures here for reference, please let me know if I can provide any other details for help with troubleshooting. I have checked previous posts but they don't help, like the link between the components already exists, I have tried to compute all the links again, a position of a moving part was modified but I have moved it back to original configuration.
gautham_kattethota
@ss38087VE7M
There appears to be an issue with Configuration 1 defined in Base Arm Configured Design.  If you open Base Arm, do you see Configuration 1 in the table?  Do you see a Repair dialog pop up?  If you do, go through that and it should hopefully fix the issue with this configuration.  If you dont see the Repair dialog, you might also not see Configuration 1 in the configurations table.   If this is true, this is related to issues other users are seeing as well and we are actively working on a fix.
But at this time, you could try and see if the workarounds suggested in this AKN article could fix it.  https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Configured-Design-...
Start with clearing the cache with instructions described in the article and check if that brings back that missing configuration.  If not, go through the workarounds suggested.
Let me know what the outcome of this is.
Regards
Gautham
Gautham Kattethota
Software Development
