Can't Update, re-Installation failes because of missing Data
dominic_siepmannSP4KD
Community Visitor
Community Visitor
"[...]No such File or Directory[...]". Wanted to Update Fusion. The Update always stopped at around 14%. When trying to update through the Installer and later trying to reinstall the error occurs. How can I fix this?
dsouzasujay
Hi @dominic_siepmannSP4KD ,
Looks like the long username is causing the problem.
Can you please check by changing the registry solves the problem?
  1. Go to windows registry editor. [Windows - Run - regedit]
  2. Navigate to FileSystem and change value from 0 to 1
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
timk60051
Community Visitor
Community Visitor
"installer is unable to find certain files to install Fusion"
dsouzasujay
Hi @timk60051,
I see the same problem, your username is long "default.DESKTOP-O46PM2U"
We are fixing the bug and we will provide an update ASAP.
For now please follow below workaround.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
