Can't stop timeline after hitting "play" button.
Przemek_Potyra
Message 1 of 9
Przemek_Potyra
Hello again. I noticed that it is very hard to stop the timeline going after pressing play by accident. In more complex designs it is a disaster. Sometimes I have to open task manager and kill F360 because it is totally unusable.
Screencast: https://autode.sk/2TylSTz
Replies (8)
Message 2 of 9
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Przemek_Potyra ,
Thanks for posting! This has been logged with the development team.
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 3 of 9
-Nick-
I have done this several times when trying to move through the timeline one event at a time and have ended up killing Fusion to get out.  Very frustrating.
Message 4 of 9
julia.paganucci
Autodesk Support
Autodesk Support
Hi @-Nick- ,
The developers have been working to get this fixed!!
Thank you for your patience,
Julia Paganucci
Message 5 of 9
TheCADWhisperer
If they still can't fix it - at least make it more difficult to hit, maybe pop up a message asking, "Are you sure you really really want to do that?  If not, you are probably about to get really really frustrated."
Message 6 of 9
-Nick-
Absolutely.  Click play and then a pop up to confirm would do the trick.
Message 7 of 9
Przemek_Potyra
Good idea ! It is very easy to click "play" by mistake while searching timeline with back/forward buttons.
Message 8 of 9
CosmotechTeam
Hi!
@julia.paganucci is there any progress on this issue? This is the most annoying bug in otherwise excellent software. And yeah, it is very frustrating and time consuming - and happens mostly when you're in a hurry and misclicks are more common, what makes it double frustrating.
I'd really appreciate a fix or even this proposed solution of a dialog box asking for confirmation of this suicide feature (which, frankly speaking, is barely useful in my opinion)
Thanks in advance!
Jake
Message 9 of 9
julia.paganucci
Autodesk Support
Autodesk Support
Hi @CosmotechTeam ,
This should be fixed in our april update. Thanks for your patience!
Julia Paganucci
