Can't stop or delet a uploading file
Truderinger
Truderinger
Hi there,
hope anyone can help.
I have a file in upload phase which is only seen in the Folder for parts where I can work on. I already deleted the original file on my computer, I deleted it online, I reinstalled Fusion twice but nothing has changed. I addition the behaviour of Fusion is weird. It works for a second then it sops for a second and so on.
How can I get rid of this sh... file?
Thanks for everyones help in advance.
Thomas
karina.harper
Autodesk Support
Autodesk Support
Hi @Truderinger,
Can you try the following:
  1. Launch Fusion
  2. Go Offline (manual switch)
  3. Close Fusion
  4. Navigate to the following location on your PC and delete the document called "login__ActiveDocuments" (your userID will look like a unique combination of letters and numbers):
    • PC:
      • %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>
  5. Launch Fusion
  6. Editable Document list should be empty
  7. Mark a single document editable
  8. Go Online
Cheers,
Karina
Truderinger
Hi Karina,
first: thank you for your fast help.
Unfortunately I have no folder called "Options" neither I can find a file called "login__ActiveDocuments".
I only have these folders below \Neutron Platform:
Regards
Thomas
karina.harper
Autodesk Support
Autodesk Support
Hi @Truderinger -
There are two "appdata" folders - one is "local" and one is "roaming".
In the top bar of the file explorer, type in %appdata% and it will take you to the roaming folder.  (%localappdata% takes you to local).
Then it will be at :
  • %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments
Cheers,
Karina
Truderinger
Sorry for the late reply, I was answering to the E-Mail.
But here again: it worked!
Thank you very much, Karina.
Regards
Thomas
