Can't select profiles for extrusion
johnAMKDR
johnAMKDR
I'm making some spokes between two circular features. The constraints were a big mess at first, perhaps due to lots of sketches. Automate/Autoconstrain got most of the things working, but when I want to extrude the spokes out of the plane, the profile selections are odd:
The middle pic looks like I'm off to a good start, but the right hand one is not what I want.
TheCADWhisperer
@johnAMKDR
Are you really really trying to make Rib features?
In any case, sketch 1, and then Pattern the feature rather than sketch elements.
Do you have a picture of something similar to your Design Intent that already exists in the real world?
johnAMKDR
The bottom of the dome is in the same plane as the top of the central tube. The spokes or ribs hold up the dome and I extruded them symetrically so that each end of the spoke would have some contact with the part it's attached to.
Here is a cross section thru the spokes (I added some meat to the tube extrusion so there would something thicker than a plane for the section to cut through.
I don't know why one of the spokes is missing some of the heavy black line. Sometimes, it would all be solid.
I want to make the spokes thinner, without the wide base at the center. I could not find a way to de-select the triangles at the base.
Here's the real object with two of the spokes showing.
TheCADWhisperer
@johnAMKDR
Did you get it all figured out?
johnAMKDR
Well, I got the part made, and if I start over, using some of your scheme, I will be able to get thinner spokes.
I'm still wondering why I selecting the profiles for extrusion did not work as expected.
TheCADWhisperer
@johnAMKDR
Looked like a bug in the sketch solver to me - but I suspect you followed a convoluted path to get there that would be difficult to reproduce (generally necessary to diagnose bugs in the program).
johnAMKDR
Yes, it is convoluted. I tried to change a parameter and the model didn't stick together. If I make another one, I'll start over.
