Can't See Cursor Color
schagj07
schagj07
Often, not sometimes, it is almost impossible to see the cursor, especially when I want it to autimatically pick a center point on an edge.  I spend extra activity changing the environment or pivoting the view to get a different "shine" on the surface I am trying to draw a sketch on.  I have perfect vision (pilot) and my color sensitivity is very high per my eye doctor, way better than normal.  I want to change the cursor and selected entities colors for MUCH higher contrast.  How can this be done and if not WHEN are you going to make this available as other softwares have it.  Please and thank you.
See Picture.
jhackney1972
If the screen capture below shows what you want to change, let me know and I will tell you where to assign the code.  I am using a dark yellow for inferred sketch constraints.
John Hackney, Retired
schagj07
Yes, that is exactly what I need to change.  I cannot see the blue they provide on the environments they provide.  I would like to try a green or a red.  Please and thank you.
schagj07
How did you change it to yellow?  This problem is killing my productivity!!!!
jhackney1972
The Windows path to the folder mentioned in the video is shown below.  I will emphasize that you should make a backup of the XML file you modify just in case you screw up and also that Fusion must be closed when you do these changes.  Please remember to select the Accept Solution icon if this helps you.
schagj07
I see a screenshot but no video, clicking on the video icon, nothing happens.  I dont understand your solution because of this.
jhackney1972
Video shows just fine for me from the Forum  I have attached the file also.
