Can't save modified design after update 21/11/2024
AndreySeleznev
Message 1 of 26
AndreySeleznev
I am unable to save any modifications in existing design after recent update.
OK button is greyed out and progress circle keep spinning.
Replies (25)
Message 2 of 26
RajkumarIlanchelian
@AndreySeleznev To clarify, if you create a new design you can save but any existing design you cannot save a modification?
Can you run that workflow and then go to Fusion help - support and diagnostics - service utility - gather system info - and attach the Fusiondiagnostics.zip file
Also, logout of Fusion/ close fusion/log back in to see if that helps?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 26
AndreySeleznev
Yes, correct I can create new design, and I can Save As current design with new name, but can't Save a version of current design.
Log out and log in didn't help.
Message 4 of 26
RajkumarIlanchelian
@AndreySeleznev Thank you for the logs. I am escalating to our engineering team.
Autodesk Fusion
Join Fusion Insider
Message 5 of 26
dlw1aes
Observer
Observer
Hi, sorry to jump on this post, but I am also having the same issue.
Message 6 of 26
RajkumarIlanchelian
Thank you for the logs. Investigating with our engineering team.
Autodesk Fusion
Join Fusion Insider
Message 7 of 26
RajkumarIlanchelian
@AndreySeleznev
 @dlw1aes We are investigating based on your logs but would like to get some more details, please.
1. Go into Fusion - help - support and diagnostics - Fusion service utility
2. Run the reset Fusion
3. Close Fusion
4. Launch Fusion
5. Run the workflow that has the save issue
6. Fusion - help - support and diagnostics - Fusion service utility
7. Gather system info
Please attach logs files again.
Autodesk Fusion
Join Fusion Insider
Message 8 of 26
AndreySeleznev
It doesn't help, but the log is attached. Here is some additional information: I can modify old 2D drawings and save. Also, one detail: I don't have admin rights on this machine, it is corporate PC managed by IT admin.
Message 9 of 26
RajkumarIlanchelian
@AndreySeleznev Thank you for the new logs. Not yet sure if this is relevant yet but we do see some network errors in the logs and could be a possible cause for what you see as many of the services that Fusion needs are failing to get access.
1. Would it be possible to launch this account on a different network and see if you are hitting the same problem?
2. Would it be possible for you to invite me raj.kumar.ilanchelian@autodesk.com into one of these projects having this issue?
Autodesk Fusion
Join Fusion Insider
Message 10 of 26
AndreySeleznev
I created new test project and test model inside. I will try other network after business hours today.
Message 11 of 26
RajkumarIlanchelian
@AndreySeleznev Another information is when you open a design do you see a badge next to it in the data panel? Like the one I have attached in the image? Screenshot 2024-11-25 at 3.01.00 PM.png
Autodesk Fusion
Join Fusion Insider
Message 12 of 26
AndreySeleznev
No I dont have any badges
Message 13 of 26
RajkumarIlanchelian
@AndreySeleznev Thank you for that confirmation. Can you invite me into that project if possible?
Autodesk Fusion
Join Fusion Insider
Message 14 of 26
AndreySeleznev
You are invited with admin rights. Cheers!
Message 15 of 26
RajkumarIlanchelian
@AndreySeleznev Thank you for the invite. In the image below you can see that I can open one of the test files, make a change and when I click on save I have the OK button enabled. You can also see the "reservations" badge in the data panel next to the design.
Almost positive now that the reservation is not happening due to "some network block" and hence the reason you cannot save.
On a new design you already have the reservation enabled since you created it on the fly and hence you are not seeing any issues to save.
Autodesk Fusion
Join Fusion Insider
Message 16 of 26
AndreySeleznev
Thank you for the information. I will try it tonight off the corporate network and talk to my IT to fix network problems.
Message 17 of 26
RajkumarIlanchelian
@AndreySeleznev Sure. Keep us informed and we can go from there.
Autodesk Fusion
Join Fusion Insider
Message 18 of 26
AndreySeleznev
By the way would you recommend installing Desktop Connector to solve that problem?
Message 19 of 26
RajkumarIlanchelian
@AndreySeleznev Likely no because when you open the file (local or cloud, I say local as when you have desktop connector installed) the file should be "reserved" for your account. This way if anyone else opens the same file and makes an edit they will be notified that another user is having this file open and their badge will now also be in the data panel next to the design.
So even if you open using desktop connector the file should be reserved for you.
Now a simple test on your machine would be, put Fusion in offline mode (manually or y disconnecting internet). Now open the test file and make a change and you WILL be able to make a change. Since there is no internet connection there is no reservation and hence the save will be enabled. This is another test to show that something is blocking the reservation of the file when you are connected to this network.
Autodesk Fusion
Join Fusion Insider
Message 20 of 26
AndreySeleznev
Thank you, just checked it. Yes I can save while it is offline. Cheers!
