Can't save drawing with structure all level
Pabiuro
Message 1 of 12
Pabiuro
I have a problem with saving drawing after new update when using feature structure "all level". In "first level" only it works ok but when I've changed to "all level" it locks on version 0 and after some time of trying to save file it shows. I've attached screen with error alert.
It's known bug? Is there any way to fix it?
Design isn't complex, after template drawing it has 100+ pages. Tried it on different designs and sometimes it works sometimes not.
Replies (11)
Message 2 of 12
ClintBrown3D
Hi @Pabiuro
That error generally usually indicates internet connectivity issues. It's worth checking if your connection has changed, or if anything else is slowing you down, like using a VPN etc.
Are you able to share some additional information with us? Perhaps the dataset to have a look at? If you would like to send it directly to me, Clint. Brown {a} Autodesk.com - I'll be able to get the team to have a look at it.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 3 of 12
Pabiuro
My designer works from home and has same issue. First time it happend yesterday on 300/30 fiber internet. Now I'm in the office with 30/30 and same problem. Tried with other larger project and same bug. It looks like projects larger than tens of pages can't be saved.
I can't share fusion team disc or designs, but I can share some data that will help you to identify bugs (only to some extend). If you could post me how to export it maybe I'll be able to help you 🙂 Maybe some logs?
Message 4 of 12
ClintBrown3D
I've just tested this on my end with a large customer dataset +-80 pages and it took a few seconds to save but there were no issues. I'm running Windows, what OS are you running?
I've asked the Dev team to reach out, could you perhaps attach your diagnostics information to this post (from the computer with the issue)
Clint Brown
Message 5 of 12
Pabiuro
I'll do more tests and will post/pm results tomorrow. Now I'm also having problems with first lvl only w/o external components 80 pages. It also could be a problem with template.
Message 6 of 12
Pabiuro
Again same problem. We found that it occure in different drawing page amount. F.e for one document now I have limit 54 pages in drawing. When I exceed it, it won't save (constant saving circle on left file browser and after some time it dissapear with error notification). Tested it with one project and different picked component(assemblies) with setting alllvl and first lvl. Only factor that seems important is page size. My components inside project are pretty simple, mostly assemblies with 2-3 components. Some of them use external our standard files with assemblies.
Tried to change template and remove some of the features but nothing has changed. Only page limit. Simpliest template I've tested only contain table with customer logo and part list.
OS: Windows
Sorry my mistake. Had long break from making projects. Problem was all the time active. My cooworker said she was making few drawings splitting design into less components all the time.
Message 7 of 12
Pabiuro
Can't generate log file. Error while doing so.
Message 8 of 12
ClintBrown3D
Hey @Pabiuro
Sorry to hear that you are having trouble. Try the manual log file collection: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Clint Brown
Message 9 of 12
Pabiuro
Ok, prepared them but can't write pm to you.
/Edit nvm my mistake
Message 10 of 12
Pramod.kadam
Hi @Pabiuro ,
We have fixed this issue in the latest Fusion version 2.0.10253. Can you please check and confirm that this is fixed for you?
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 11 of 12
Pabiuro
Hey,
thanks! Sorry for delay but it's working now 🙂
Message 12 of 12
Pramod.kadam
Hi @Pabiuro ,
Great that issue got resolved.
Pramod Kadam
Product Owner
Fusion 360 Drawings
