Can't Save Document
Can't Save Document
Can't Save Document
I spent most of this day making a design on fusion 360.  When it came to exporting it as an STL I was told I needed to save it first.  I'm aware of this requirement and it hasn't been a problem in the past.
However when the save dialogue comes up clicking the save button doesn't do anything.  I've tried refreshing, clicking it multiple times, I've tried using different names.
I've got less than 10 projects so that isn't an issue.  While fusion 360 is still open I can open new projects and edit, save them.  I also seem to be logged in.
I would try restarting it but I'm worried I will lose all my work!
I would appreciate some help with this.
Thanks!
jhackney1972
Before doing anything else, go to the File menu, select Export and save to the folder of your choice on your local hard drive.  Depending on your model, the file could be saved as a F3D or F3Z file.
John Hackney, Retired
I've tried doing that, but I get the same problem.  A dialogue box that doesn't do anything when I click on save.
