Can't place decal correctly because surface geometry confines controller
rlytelMNNZ8
rlytelMNNZ8
Working on modeling a kitchen timer.  The top surface is a domed ring.  when I attempt to place a decal, the center portion prohibits my placing the graphics in the proper location.  Typing in the coordinates in the dialog box also does not work.  Any ideas?
Thanks!
g-andresen
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
jeff_strater
yeah, this a known and unfortunate issue with decal.  The problem is needing a spot on the surface to place the decal, and if there is no material there, Fusion can't do that.  It is on our list to fix.
The usual workaround is to create another surface body, remove or patch the hole to give you some material there, and place the decal on that body.  Then, turn the opacity down to zero to hide it.  In the screencast, I actually moved the duplicate up by .25mm to avoid z-fighting with the original.  Messy, I know...
Jeff Strater
Engineering Director
rlytelMNNZ8
Thank you! I'll work it around.  Great product.
