Can't open Fusion, was using it yesterday with no issues
divebomb8KKBX
divebomb8KKBX
I was using Fusion yesterday and it was working fine. Windows 10 Pro
Will not open today.
RajkumarIlanchelian
@divebomb8KKBX Can you please provide more information on what exactly is happening?
1. When you launch Fusion is it hanging on the splash screen? Is it opening and then quickly exiting to the desktop?
2. Does a restart of the machine help in any way?
3. If you disconnect internet and start Fusion, does it launch? (If it does when you connect back does it stop responding again?)
It would also help if we can get the 3 logs calls out in this article - https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
4.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
dsouzasujay
Hi @divebomb8KKBX,
Try Uninstall and Reinstalling Fusion again, Refer below document
If its still not working, Do a clean uninstall and try again
Still not working?
Please attach the installation log file to the next reply, from below location
  • C:\Users\(username)\Appdata\Local\Autodesk\autodesk.webdeploy.streamer.log
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
divebomb8KKBX
Doesn't even go to the Splash
Restarted a few times, no help
I'll try disconnecting internet
divebomb8KKBX
Disconnecting did not help
Will uninstall and re-install
divebomb8KKBX
What's the best download link when paying monthly?
dsouzasujay
Hi @divebomb8KKBX
You can download from your account
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
