Can't Open cloud file
TDkinc09
TDkinc09
Community Visitor
Community Visitor
I get this error when I am trying to open a saved file. It seems that I've lost a good amount of work if I can't get this open. Unfortunately This seems like a fusion 360 issue and not my issue, but I don't have a subscription for support.
Zip64: failed to open a zip package. - Failed to open zip package C:/Users/toolm/AppData/Local/Autodesk/Autodesk Fusion 360/TM98JH7ZRVEQ/W.login/F/_Destroyer V2.1b7531bb-5bbd-423c-9297-0f066ad0f73c.f3d.
The file C:/Users/toolm/AppData/Local/Autodesk/Autodesk Fusion 360/TM98JH7ZRVEQ/W.login/F/_Destroyer V2.1b7531bb-5bbd-423c-9297-0f066ad0f73c.f3d could not be opened. It is probably locked by another program.
The file C:/Users/toolm/AppData/Local/Autodesk/Autodesk Fusion 360/TM98JH7ZRVEQ/W.login/F/_Destroyer V2.1b7531bb-5bbd-423c-9297-0f066ad0f73c.f3d could not be loaded.
jhackney1972
Try navigating to the file mentioned in the error on your hard drive.  Copy it to another folder and then try and use the Open, from Local Folder, option.
John Hackney, Retired
