Can't Mark Design as "Read Only" because "Upload In Progress"
Zam577
Zam577
This single design has been stuck in my editable document list for a few days now. I have tried signing out and back in, restarting Fusion on my M4 Macbook Pro, and deleting the design from the web interface. It still stays here, though.
I have made and marked editable/uneditable many other designs, but it is only this one which is being difficult.
I have tried running Fusion.CancelUploads/Force and got this response:
Files which were removed from queue and not uploaded:
Files removed from queue and not Uploaded : 0
Thanks!
RajkumarIlanchelian
@Zam577 @Can you please follow the below article for a solution?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Zam577
Ideally Autodesk would fix this issue (that's kind of their job), but that did work. I hadn't been able to find that article before. Thanks.
RajkumarIlanchelian
@Zam577 @What version for Fusion are you using? We did fix this recently.
Autodesk Fusion
Join Fusion Insider
Zam577
I'm using the latest version.
RajkumarIlanchelian
@Zam577 @When you get a chance please paste the version number here.
if you hit this issue again please come back to this thread.
Autodesk Fusion
Join Fusion Insider
Zam577
Fusion 2.0.20981 arm64 [Native]
Active Plan: Personal
macOS 15.2 (24C101) on Mac16,8
I clicked "Check for Updates" and it said none were found.
