Can't join objects together
poultonsDN5LR
poultonsDN5LR
If I draw a simple cube and save it then on anew workspace draw another cube save it, then I try to join, I select the two sides I want to join them but get the message attached. What does it mean? I have tried to draw different cube type shapes and sometimes it works and sometimes the joint does not work.
Please can somebody advise.
davebYYPCU
If you have 2 components in the Browser,
UnPin the second component from Parent, so that it is allowed to move.
If not 2 components, then the Joint is wrong function.
Might help...
jeff_strater
That error is unrelated to the Combine.  If the design is in the state before drawing your first cube, try doing a Compute All - I suspect that you will see the same error.  The error appears only because the Combine forces a compute.  So, as @davebYYPCU suggests, you need to look at your components and joints to see where the error is occurring.
Jeff Strater
Engineering Director
