Can't Install Fusion 360
I get to 99% and I get an error. It says "we are not sure what is preventing the installation. (-2147024894, 'The system cannot find the file specified.' (None, None, None, 0, None))"
Attached is the log file from the error. I tried to reinstall it several times and still the same error. Tried the clean uninstall and reinstall it and the problem is still there.
2019-06-19 19:25:46,314 - MainProcess(14656) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2019-06-19 19:25:46,318 - MainProcess(14656) - MainThread - adsk.dls.streamer - INFO :: # #
2019-06-19 19:25:46,318 - MainProcess(14656) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000210258CB048> #
2019-06-19 19:25:46,319 - MainProcess(14656) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2019-06-19 19:25:46,319 - MainProcess(14656) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\santo\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2019-06-19 19:25:46,320 - MainProcess(14656) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\santo\AppData\Local\Temp\7zS7500.tmp\resources\buildinfo.json
2019-06-19 19:25:46,322 - MainProcess(14656) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2019-06-19 19:25:46,324 - MainProcess(14656) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2019-06-19 19:25:46,324 - MainProcess(14656) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20190226171444
2019-06-19 19:25:46,324 - MainProcess(14656) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2019-06-19 19:25:46,325 - MainProcess(14656) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\santo\AppData\Local\Temp\7zS7500.tmp\resources
2019-06-19 19:25:46,326 - MainProcess(14656) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loaded extra streams: {}
2019-06-19 19:25:46,327 - MainProcess(14656) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2019-06-19 19:25:46,329 - MainProcess(14656) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2019-06-19 19:25:46,330 - MainProcess(14656) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2019-06-19 19:25:46,330 - MainProcess(14656) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x00000210258C0158>, pipes=None, procfac=<function deploy_process at 0x00000210258BED08>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2019-06-19 19:25:46,331 - MainProcess(14656) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2019-06-19 19:25:46,331 - MainProcess(14656) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2019-06-19 19:25:46,332 - MainProcess(14656) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2019-06-19 19:25:46,334 - MainProcess(14656) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2019-06-19 19:25:46,335 - MainProcess(14656) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2019-06-19 19:25:46,880 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2019-06-19 19:25:46,897 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2019-06-19 19:25:46,898 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2019-06-19 19:25:48,033 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json
2019-06-19 19:25:48,040 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2019-06-19 19:25:48,152 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 184.28.179.28
2019-06-19 19:25:48,189 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2019-06-19 19:25:48,196 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MTg0LjI4LjE3OS4yOA==
2019-06-19 19:25:48,197 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjE0MQ==
2019-06-19 19:25:48,197 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2019-06-19 19:25:48,346 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: The session id is bcdf1725-c57d-446b-9cef-254d39347c81
2019-06-19 19:25:48,695 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Configure app begin Deploy to 2.0.5827 for app 73e72ada57b7480280f7a6f4a289729f
2019-06-19 19:25:48,695 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2019-06-19 19:25:48,697 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.platform - INFO :: Required OS version: [6, 1]
2019-06-19 19:25:48,710 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c98e2c530df6f63f7c4dfc83d9d00e3f547206e4
2019-06-19 19:25:48,710 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c98e2c530df6f63f7c4dfc83d9d00e3f547206e4.json
2019-06-19 19:25:48,901 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c98e2c530df6f63f7c4dfc83d9d00e3f547206e4.tar.xz for package c98e2c530df6f63f7c4dfc83d9d00e3f547206e4
2019-06-19 19:25:48,902 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c7b5549effb919f877117252f2c3954fcf5fb9aa
2019-06-19 19:25:48,908 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c7b5549effb919f877117252f2c3954fcf5fb9aa.json
2019-06-19 19:25:49,064 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:25:49,064 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path does not exist. Creating
2019-06-19 19:25:49,073 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c7b5549effb919f877117252f2c3954fcf5fb9aa.tar.xz for package c7b5549effb919f877117252f2c3954fcf5fb9aa
2019-06-19 19:25:49,073 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 5cb7b00e7ba54ba64846d2fa06e9f06e253e20d4
2019-06-19 19:25:49,079 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5cb7b00e7ba54ba64846d2fa06e9f06e253e20d4.json
2019-06-19 19:25:49,272 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:25:49,273 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5cb7b00e7ba54ba64846d2fa06e9f06e253e20d4.tar.xz for package 5cb7b00e7ba54ba64846d2fa06e9f06e253e20d4
2019-06-19 19:25:49,274 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: f7c002c947c51f96c266090790ed5ece993488bb
2019-06-19 19:25:49,282 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f7c002c947c51f96c266090790ed5ece993488bb.json
2019-06-19 19:25:49,358 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:25:49,462 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f7c002c947c51f96c266090790ed5ece993488bb.tar.xz for package f7c002c947c51f96c266090790ed5ece993488bb
2019-06-19 19:25:49,463 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: ca5d25b9695a030ddac2b6e97abc062c8aa9c124
2019-06-19 19:25:49,463 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ca5d25b9695a030ddac2b6e97abc062c8aa9c124.json
2019-06-19 19:25:49,481 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:25:49,837 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 366c026cce54fc0824afc56aa32e4e9a45e4f596
2019-06-19 19:25:49,838 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/366c026cce54fc0824afc56aa32e4e9a45e4f596.json
2019-06-19 19:25:49,838 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ca5d25b9695a030ddac2b6e97abc062c8aa9c124.tar.xz for package ca5d25b9695a030ddac2b6e97abc062c8aa9c124
2019-06-19 19:25:49,869 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:25:50,106 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:25:50,121 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 74b28665f32e48545e599cd9bd144717403795e6
2019-06-19 19:25:50,122 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/74b28665f32e48545e599cd9bd144717403795e6.json
2019-06-19 19:25:50,477 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 42cf4a5c4ca3439d1a0b8254038d5d5cd095520b
2019-06-19 19:25:50,479 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/42cf4a5c4ca3439d1a0b8254038d5d5cd095520b.json
2019-06-19 19:25:50,648 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:25:50,651 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/366c026cce54fc0824afc56aa32e4e9a45e4f596.tar.xz for package 366c026cce54fc0824afc56aa32e4e9a45e4f596
2019-06-19 19:25:50,758 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 954d4de038c32e4033a91db891eae5c89e4927c7
2019-06-19 19:25:50,760 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/954d4de038c32e4033a91db891eae5c89e4927c7.json
2019-06-19 19:25:51,048 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:25:51,126 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 4b2c477172f86b97ab380c972d124b0fe4510670
2019-06-19 19:25:51,127 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4b2c477172f86b97ab380c972d124b0fe4510670.json
2019-06-19 19:25:51,796 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1183137b21cc6267e8938d69cbd1012fbd27685c
2019-06-19 19:25:51,797 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1183137b21cc6267e8938d69cbd1012fbd27685c.json
2019-06-19 19:25:52,339 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 49d3c685c7e981d7ffa195e8075b7ec2608da5ac
2019-06-19 19:25:52,341 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/49d3c685c7e981d7ffa195e8075b7ec2608da5ac.json
2019-06-19 19:25:52,352 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:25:52,357 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/74b28665f32e48545e599cd9bd144717403795e6.tar.xz for package 74b28665f32e48545e599cd9bd144717403795e6
2019-06-19 19:25:53,239 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: a2b5468b932ea0d555841ef9e2202daad2fd3817
2019-06-19 19:25:53,239 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a2b5468b932ea0d555841ef9e2202daad2fd3817.json
2019-06-19 19:25:53,287 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:25:54,291 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c56f7e2b66e417774e0974c0dd145fd9986d3385
2019-06-19 19:25:54,291 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c56f7e2b66e417774e0974c0dd145fd9986d3385.json
2019-06-19 19:25:55,480 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: d96ff68869cd588bbf29f76e887996bfa492cc8e
2019-06-19 19:25:55,480 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d96ff68869cd588bbf29f76e887996bfa492cc8e.json
2019-06-19 19:25:56,059 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: a879e8ba7a73a5bc21b668299a516d968ca1e7ba
2019-06-19 19:25:56,059 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a879e8ba7a73a5bc21b668299a516d968ca1e7ba.json
2019-06-19 19:25:56,453 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 4768c1b8c43c4d96436bcb1c26b5e22070a4a0cb
2019-06-19 19:25:56,454 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4768c1b8c43c4d96436bcb1c26b5e22070a4a0cb.json
2019-06-19 19:25:56,670 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: a737335b3060148c6e58e937a891a082e586e705
2019-06-19 19:25:56,671 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a737335b3060148c6e58e937a891a082e586e705.json
2019-06-19 19:25:56,874 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: ed7fedcbb462c513b85683ec630de74d26ab46b3
2019-06-19 19:25:56,878 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ed7fedcbb462c513b85683ec630de74d26ab46b3.json
2019-06-19 19:25:57,147 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: b34776429a3a3f9bad6019d8d9f804b3994e25c6
2019-06-19 19:25:57,147 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b34776429a3a3f9bad6019d8d9f804b3994e25c6.json
2019-06-19 19:25:57,433 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1376151b635500a0221917e1e469964613ac2065
2019-06-19 19:25:57,436 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1376151b635500a0221917e1e469964613ac2065.json
2019-06-19 19:25:57,793 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 2280bb386007eef2ff3f8b2748b814ca4827bee4
2019-06-19 19:25:57,793 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2280bb386007eef2ff3f8b2748b814ca4827bee4.json
2019-06-19 19:25:58,078 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: cd41346859d342d3e377b810a59511a9a3d19b1b
2019-06-19 19:25:58,078 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cd41346859d342d3e377b810a59511a9a3d19b1b.json
2019-06-19 19:25:58,374 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: d1b5836c48096a2e53d20f2a8bb204243209c55e
2019-06-19 19:25:58,375 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d1b5836c48096a2e53d20f2a8bb204243209c55e.json
2019-06-19 19:25:58,682 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1f1157b29386e7a81f31d7c54b99737ee2e15bc4
2019-06-19 19:25:58,682 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1f1157b29386e7a81f31d7c54b99737ee2e15bc4.json
2019-06-19 19:25:58,994 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: adb012a2e6e27480b9554d4b2d1b460f64787bdb
2019-06-19 19:25:58,995 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/adb012a2e6e27480b9554d4b2d1b460f64787bdb.json
2019-06-19 19:25:59,225 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: d9298cc441918b8a7f5d0422f9e8ce440b276fae
2019-06-19 19:25:59,225 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d9298cc441918b8a7f5d0422f9e8ce440b276fae.json
2019-06-19 19:25:59,495 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 544690c71d3e8b33361e609290e036553d630e92
2019-06-19 19:25:59,496 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/544690c71d3e8b33361e609290e036553d630e92.json
2019-06-19 19:25:59,823 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 731caf962da009bc4067b4db4301f930dde282c3
2019-06-19 19:25:59,823 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/731caf962da009bc4067b4db4301f930dde282c3.json
2019-06-19 19:26:00,099 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: a65f956f03d6d5d7a2fcb347006b6bbe163b5b10
2019-06-19 19:26:00,100 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a65f956f03d6d5d7a2fcb347006b6bbe163b5b10.json
2019-06-19 19:26:00,387 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 6c93684d98f9b6265d1433207a37a0a8719e40ee
2019-06-19 19:26:00,388 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6c93684d98f9b6265d1433207a37a0a8719e40ee.json
2019-06-19 19:26:00,695 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: d2876841e4323823816f0fdc389cea46292ab3ed
2019-06-19 19:26:00,696 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d2876841e4323823816f0fdc389cea46292ab3ed.json
2019-06-19 19:26:01,028 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 6026230caf93d2ca4ea71cecc80e8bfc7927e610
2019-06-19 19:26:01,030 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6026230caf93d2ca4ea71cecc80e8bfc7927e610.json
2019-06-19 19:26:01,342 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 31ee8e7065829fc5a60e88c42436ce5e0b29d77d
2019-06-19 19:26:01,344 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/31ee8e7065829fc5a60e88c42436ce5e0b29d77d.json
2019-06-19 19:26:01,675 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 8c316f6401312ea6f171794ea6acf853d7f2a166
2019-06-19 19:26:01,676 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8c316f6401312ea6f171794ea6acf853d7f2a166.json
2019-06-19 19:26:01,919 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: cd398d360d746179da04a19fe608256034f75a64
2019-06-19 19:26:01,920 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cd398d360d746179da04a19fe608256034f75a64.json
2019-06-19 19:26:02,132 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1c0d6bae7a249935add83f80edc2a51a7ee8953d
2019-06-19 19:26:02,133 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1c0d6bae7a249935add83f80edc2a51a7ee8953d.json
2019-06-19 19:26:02,346 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 064dcebf3d0e6489859d0f4fb58542b83a861a4b
2019-06-19 19:26:02,347 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/064dcebf3d0e6489859d0f4fb58542b83a861a4b.json
2019-06-19 19:26:02,567 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: ff801e23a542496dde268f3ed8fe35e1127d8a98
2019-06-19 19:26:02,567 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ff801e23a542496dde268f3ed8fe35e1127d8a98.json
2019-06-19 19:26:02,795 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e310e6a411f6304052be63c519951937834bcc91
2019-06-19 19:26:02,796 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e310e6a411f6304052be63c519951937834bcc91.json
2019-06-19 19:26:03,068 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: ef6bc9523775e8a04db11fb489207468d9f450b4
2019-06-19 19:26:03,069 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ef6bc9523775e8a04db11fb489207468d9f450b4.json
2019-06-19 19:26:03,304 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 068139681db8debdd88176e4058de5b6b8925254
2019-06-19 19:26:03,305 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/068139681db8debdd88176e4058de5b6b8925254.json
2019-06-19 19:26:03,539 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 689031f6e7d02c8b3dc7f5cf3f76d213aa641ef9
2019-06-19 19:26:03,539 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/689031f6e7d02c8b3dc7f5cf3f76d213aa641ef9.json
2019-06-19 19:26:03,733 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 5050e42a9a2dc6e76931bcf98ba255e2b80ba2cb
2019-06-19 19:26:03,733 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5050e42a9a2dc6e76931bcf98ba255e2b80ba2cb.json
2019-06-19 19:26:04,069 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Start executing tasks thread
2019-06-19 19:26:04,071 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for c98e2c530df6f63f7c4dfc83d9d00e3f547206e4
2019-06-19 19:26:12,008 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:12,024 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/42cf4a5c4ca3439d1a0b8254038d5d5cd095520b.tar.xz for package 42cf4a5c4ca3439d1a0b8254038d5d5cd095520b
2019-06-19 19:26:12,242 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:21,469 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:21,481 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/954d4de038c32e4033a91db891eae5c89e4927c7.tar.xz for package 954d4de038c32e4033a91db891eae5c89e4927c7
2019-06-19 19:26:22,084 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:28,932 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:28,941 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4b2c477172f86b97ab380c972d124b0fe4510670.tar.xz for package 4b2c477172f86b97ab380c972d124b0fe4510670
2019-06-19 19:26:29,144 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:29,230 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:29,245 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1183137b21cc6267e8938d69cbd1012fbd27685c.tar.xz for package 1183137b21cc6267e8938d69cbd1012fbd27685c
2019-06-19 19:26:29,433 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:29,597 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:29,601 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/49d3c685c7e981d7ffa195e8075b7ec2608da5ac.tar.xz for package 49d3c685c7e981d7ffa195e8075b7ec2608da5ac
2019-06-19 19:26:29,806 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:30,318 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:30,323 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a2b5468b932ea0d555841ef9e2202daad2fd3817.tar.xz for package a2b5468b932ea0d555841ef9e2202daad2fd3817
2019-06-19 19:26:30,361 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:30,364 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c56f7e2b66e417774e0974c0dd145fd9986d3385.tar.xz for package c56f7e2b66e417774e0974c0dd145fd9986d3385
2019-06-19 19:26:30,506 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:30,540 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:30,778 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:30,782 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d96ff68869cd588bbf29f76e887996bfa492cc8e.tar.xz for package d96ff68869cd588bbf29f76e887996bfa492cc8e
2019-06-19 19:26:31,207 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:33,898 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:33,907 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a879e8ba7a73a5bc21b668299a516d968ca1e7ba.tar.xz for package a879e8ba7a73a5bc21b668299a516d968ca1e7ba
2019-06-19 19:26:34,117 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:34,284 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:34,288 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4768c1b8c43c4d96436bcb1c26b5e22070a4a0cb.tar.xz for package 4768c1b8c43c4d96436bcb1c26b5e22070a4a0cb
2019-06-19 19:26:34,482 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:35,546 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:35,550 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a737335b3060148c6e58e937a891a082e586e705.tar.xz for package a737335b3060148c6e58e937a891a082e586e705
2019-06-19 19:26:35,730 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:36,047 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:36,051 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ed7fedcbb462c513b85683ec630de74d26ab46b3.tar.xz for package ed7fedcbb462c513b85683ec630de74d26ab46b3
2019-06-19 19:26:36,947 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:37,568 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:37,570 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b34776429a3a3f9bad6019d8d9f804b3994e25c6.tar.xz for package b34776429a3a3f9bad6019d8d9f804b3994e25c6
2019-06-19 19:26:37,778 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:37,791 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1376151b635500a0221917e1e469964613ac2065.tar.xz for package 1376151b635500a0221917e1e469964613ac2065
2019-06-19 19:26:37,792 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for c7b5549effb919f877117252f2c3954fcf5fb9aa
2019-06-19 19:26:37,863 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 5cb7b00e7ba54ba64846d2fa06e9f06e253e20d4
2019-06-19 19:26:37,919 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for f7c002c947c51f96c266090790ed5ece993488bb
2019-06-19 19:26:37,940 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for ca5d25b9695a030ddac2b6e97abc062c8aa9c124
2019-06-19 19:26:37,994 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 366c026cce54fc0824afc56aa32e4e9a45e4f596
2019-06-19 19:26:38,485 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:38,490 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:42,442 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:42,444 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2280bb386007eef2ff3f8b2748b814ca4827bee4.tar.xz for package 2280bb386007eef2ff3f8b2748b814ca4827bee4
2019-06-19 19:26:42,928 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:43,419 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:43,435 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cd41346859d342d3e377b810a59511a9a3d19b1b.tar.xz for package cd41346859d342d3e377b810a59511a9a3d19b1b
2019-06-19 19:26:43,503 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:43,509 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d1b5836c48096a2e53d20f2a8bb204243209c55e.tar.xz for package d1b5836c48096a2e53d20f2a8bb204243209c55e
2019-06-19 19:26:43,694 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:43,731 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:46,759 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:46,769 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1f1157b29386e7a81f31d7c54b99737ee2e15bc4.tar.xz for package 1f1157b29386e7a81f31d7c54b99737ee2e15bc4
2019-06-19 19:26:46,994 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:47,383 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:47,389 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/adb012a2e6e27480b9554d4b2d1b460f64787bdb.tar.xz for package adb012a2e6e27480b9554d4b2d1b460f64787bdb
2019-06-19 19:26:47,643 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:26:48,674 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:26:48,679 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7cd5cb01aed46127bae0cfe24897c1e0b6cf7a87.tar.xz for package d9298cc441918b8a7f5d0422f9e8ce440b276fae
2019-06-19 19:26:49,001 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:26:49,001 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path does not exist. Creating
2019-06-19 19:27:05,346 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:27:05,362 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/383ccfaa52cb5648ac65e1c0698b6c9c3111f4f1.tar.xz for package d9298cc441918b8a7f5d0422f9e8ce440b276fae
2019-06-19 19:27:05,645 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:27:21,100 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:27:21,111 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5fcdd1d4e876d7af27327ade1e28e1a19817cdbd.tar.xz for package d9298cc441918b8a7f5d0422f9e8ce440b276fae
2019-06-19 19:27:22,591 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:27:22,603 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/544690c71d3e8b33361e609290e036553d630e92.tar.xz for package 544690c71d3e8b33361e609290e036553d630e92
2019-06-19 19:27:24,023 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:27:24,579 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\Common
2019-06-19 19:28:02,270 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:28:02,283 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/79be363418fc3802e067337db1b1860e4e46a0ea.tar.xz for package 731caf962da009bc4067b4db4301f930dde282c3
2019-06-19 19:28:02,624 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:04,820 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:28:04,839 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2f3366f463209795118114cbb50e511d179b45dc.tar.xz for package a65f956f03d6d5d7a2fcb347006b6bbe163b5b10
2019-06-19 19:28:04,839 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 74b28665f32e48545e599cd9bd144717403795e6
2019-06-19 19:28:05,119 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:05,822 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:28:05,825 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/af324d0f5136a80db8fb463bddeed5cbfba0ec2e.tar.xz for package 6c93684d98f9b6265d1433207a37a0a8719e40ee
2019-06-19 19:28:06,314 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 42cf4a5c4ca3439d1a0b8254038d5d5cd095520b
2019-06-19 19:28:06,361 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 954d4de038c32e4033a91db891eae5c89e4927c7
2019-06-19 19:28:06,397 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 4b2c477172f86b97ab380c972d124b0fe4510670
2019-06-19 19:28:06,440 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 1183137b21cc6267e8938d69cbd1012fbd27685c
2019-06-19 19:28:06,462 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 49d3c685c7e981d7ffa195e8075b7ec2608da5ac
2019-06-19 19:28:06,493 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for a2b5468b932ea0d555841ef9e2202daad2fd3817
2019-06-19 19:28:06,523 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for c56f7e2b66e417774e0974c0dd145fd9986d3385
2019-06-19 19:28:06,543 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for d96ff68869cd588bbf29f76e887996bfa492cc8e
2019-06-19 19:28:06,712 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for a879e8ba7a73a5bc21b668299a516d968ca1e7ba
2019-06-19 19:28:06,765 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 4768c1b8c43c4d96436bcb1c26b5e22070a4a0cb
2019-06-19 19:28:06,820 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for a737335b3060148c6e58e937a891a082e586e705
2019-06-19 19:28:06,849 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for ed7fedcbb462c513b85683ec630de74d26ab46b3
2019-06-19 19:28:06,872 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:06,882 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for b34776429a3a3f9bad6019d8d9f804b3994e25c6
2019-06-19 19:28:06,904 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 1376151b635500a0221917e1e469964613ac2065
2019-06-19 19:28:06,938 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 2280bb386007eef2ff3f8b2748b814ca4827bee4
2019-06-19 19:28:06,959 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for cd41346859d342d3e377b810a59511a9a3d19b1b
2019-06-19 19:28:06,990 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for d1b5836c48096a2e53d20f2a8bb204243209c55e
2019-06-19 19:28:07,254 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 1f1157b29386e7a81f31d7c54b99737ee2e15bc4
2019-06-19 19:28:07,281 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for adb012a2e6e27480b9554d4b2d1b460f64787bdb
2019-06-19 19:28:22,156 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:28:22,160 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/abc949234dd7bf6cb2e318260499720463fde14b.tar.xz for package d2876841e4323823816f0fdc389cea46292ab3ed
2019-06-19 19:28:22,792 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:45,044 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:28:45,054 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9e440437eb97f6cb3b165b2686ff40f5d97268f5.tar.xz for package d2876841e4323823816f0fdc389cea46292ab3ed
2019-06-19 19:28:45,401 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:46,841 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:28:46,865 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d3bb8aa84b6af3cdfaeb2fe529777edd5f741571.tar.xz for package d2876841e4323823816f0fdc389cea46292ab3ed
2019-06-19 19:28:46,875 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Begin perform postdeploy tasks for package d9298cc441918b8a7f5d0422f9e8ce440b276fae
2019-06-19 19:28:47,102 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:47,456 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "c98e2c530df6f63f7c4dfc83d9d00e3f547206e4" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:47,491 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "c7b5549effb919f877117252f2c3954fcf5fb9aa" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:47,696 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:28:47,699 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4a60e0985c35103a0f5fb06d3a1b542b97f156d2.tar.xz for package 6026230caf93d2ca4ea71cecc80e8bfc7927e610
2019-06-19 19:28:47,954 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:48,279 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "5cb7b00e7ba54ba64846d2fa06e9f06e253e20d4" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:48,794 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "f7c002c947c51f96c266090790ed5ece993488bb" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:48,822 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "ca5d25b9695a030ddac2b6e97abc062c8aa9c124" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:48,956 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "366c026cce54fc0824afc56aa32e4e9a45e4f596" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:28:48,974 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "74b28665f32e48545e599cd9bd144717403795e6" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:01,611 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:01,625 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/79ceb840101f04dc13e6649b9181887d9c221271.tar.xz for package 6026230caf93d2ca4ea71cecc80e8bfc7927e610
2019-06-19 19:29:01,879 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:05,210 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "42cf4a5c4ca3439d1a0b8254038d5d5cd095520b" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:05,758 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "954d4de038c32e4033a91db891eae5c89e4927c7" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,298 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "4b2c477172f86b97ab380c972d124b0fe4510670" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,325 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "1183137b21cc6267e8938d69cbd1012fbd27685c" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,352 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "49d3c685c7e981d7ffa195e8075b7ec2608da5ac" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,380 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "a2b5468b932ea0d555841ef9e2202daad2fd3817" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,403 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "c56f7e2b66e417774e0974c0dd145fd9986d3385" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,438 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "d96ff68869cd588bbf29f76e887996bfa492cc8e" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,706 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "a879e8ba7a73a5bc21b668299a516d968ca1e7ba" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,722 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "4768c1b8c43c4d96436bcb1c26b5e22070a4a0cb" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,757 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "a737335b3060148c6e58e937a891a082e586e705" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,782 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "ed7fedcbb462c513b85683ec630de74d26ab46b3" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,806 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "b34776429a3a3f9bad6019d8d9f804b3994e25c6" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,834 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "1376151b635500a0221917e1e469964613ac2065" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,855 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "2280bb386007eef2ff3f8b2748b814ca4827bee4" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,877 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "cd41346859d342d3e377b810a59511a9a3d19b1b" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:06,911 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "d1b5836c48096a2e53d20f2a8bb204243209c55e" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:11,765 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:11,784 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/54c23bea8093f2d85bfe02e6923c462b718c7e7c.tar.xz for package 6026230caf93d2ca4ea71cecc80e8bfc7927e610
2019-06-19 19:29:12,029 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:12,072 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "1f1157b29386e7a81f31d7c54b99737ee2e15bc4" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:12,093 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "adb012a2e6e27480b9554d4b2d1b460f64787bdb" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:12,194 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - WARNING :: Special action "36d909d4c5304fc2a6a47bbb9116f50e" was not in registry
2019-06-19 19:29:12,194 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Complete perform postdeploy tasks for package d9298cc441918b8a7f5d0422f9e8ce440b276fae
2019-06-19 19:29:12,195 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for d9298cc441918b8a7f5d0422f9e8ce440b276fae
2019-06-19 19:29:14,883 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Begin perform postdeploy tasks for package 544690c71d3e8b33361e609290e036553d630e92
2019-06-19 19:29:14,926 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Executing: "\\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc\MaterialLibraryMigrator.exe" "migratecache" "C:\Users\santo\AppData\Local\Autodesk\Common\Material Library"
2019-06-19 19:29:16,257 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - WARNING :: Special action "c1d5a6c7dcbf4562b683600beeae3d5f" was not in registry
2019-06-19 19:29:16,257 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Complete perform postdeploy tasks for package 544690c71d3e8b33361e609290e036553d630e92
2019-06-19 19:29:16,258 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 544690c71d3e8b33361e609290e036553d630e92
2019-06-19 19:29:16,625 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 731caf962da009bc4067b4db4301f930dde282c3
2019-06-19 19:29:18,021 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for a65f956f03d6d5d7a2fcb347006b6bbe163b5b10
2019-06-19 19:29:18,087 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 6c93684d98f9b6265d1433207a37a0a8719e40ee
2019-06-19 19:29:35,382 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:35,399 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5959d45cfa3514248940638d25a497b725998925.tar.xz for package 6026230caf93d2ca4ea71cecc80e8bfc7927e610
2019-06-19 19:29:35,644 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:44,200 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:44,215 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/31ee8e7065829fc5a60e88c42436ce5e0b29d77d.tar.xz for package 31ee8e7065829fc5a60e88c42436ce5e0b29d77d
2019-06-19 19:29:44,474 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:29:48,814 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:48,830 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/83d289d8225b700efa2801a409cbeeae34114051.tar.xz for package 8c316f6401312ea6f171794ea6acf853d7f2a166
2019-06-19 19:29:49,131 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:49,139 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cd398d360d746179da04a19fe608256034f75a64.tar.xz for package cd398d360d746179da04a19fe608256034f75a64
2019-06-19 19:29:49,360 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2019-06-19 19:29:49,360 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path does not exist. Creating
2019-06-19 19:29:49,418 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:29:49,613 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:49,617 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1c0d6bae7a249935add83f80edc2a51a7ee8953d.tar.xz for package 1c0d6bae7a249935add83f80edc2a51a7ee8953d
2019-06-19 19:29:50,207 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:29:54,159 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:54,164 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/064dcebf3d0e6489859d0f4fb58542b83a861a4b.tar.xz for package 064dcebf3d0e6489859d0f4fb58542b83a861a4b
2019-06-19 19:29:58,097 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:29:58,236 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:29:58,239 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ff801e23a542496dde268f3ed8fe35e1127d8a98.tar.xz for package ff801e23a542496dde268f3ed8fe35e1127d8a98
2019-06-19 19:29:58,499 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:30:01,216 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:30:01,227 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e310e6a411f6304052be63c519951937834bcc91.tar.xz for package e310e6a411f6304052be63c519951937834bcc91
2019-06-19 19:30:01,393 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\shared
2019-06-19 19:30:01,494 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:30:01,499 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d9a0c8f082a5176a61e0c29905f40e6d2506f181.tar.xz for package ef6bc9523775e8a04db11fb489207468d9f450b4
2019-06-19 19:30:01,578 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:30:01,580 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3bc130f393cd664ffddda1fc78630214daa2a21f.tar.xz for package 068139681db8debdd88176e4058de5b6b8925254
2019-06-19 19:30:01,696 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:30:01,784 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:30:15,468 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:30:15,476 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/54f549ebb8e8e4e79c8a775ac46ee382439decf3.tar.xz for package 689031f6e7d02c8b3dc7f5cf3f76d213aa641ef9
2019-06-19 19:30:15,737 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:30:16,098 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:30:16,101 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4d3f3592d3cc6808afe9afabb61814bf2966d41d.tar.xz for package 5050e42a9a2dc6e76931bcf98ba255e2b80ba2cb
2019-06-19 19:30:16,425 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:30:20,659 - MainProcess(14656) - Thread-3 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:30:23,545 - MainProcess(14656) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:30:29,036 - MainProcess(14656) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:31:05,744 - MainProcess(14656) - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2019-06-19 19:31:05,771 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for d2876841e4323823816f0fdc389cea46292ab3ed
2019-06-19 19:31:06,804 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 6026230caf93d2ca4ea71cecc80e8bfc7927e610
2019-06-19 19:31:06,930 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 31ee8e7065829fc5a60e88c42436ce5e0b29d77d
2019-06-19 19:31:06,981 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Begin perform postdeploy tasks for package 8c316f6401312ea6f171794ea6acf853d7f2a166
2019-06-19 19:31:06,987 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "31ee8e7065829fc5a60e88c42436ce5e0b29d77d" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:31:07,032 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Complete perform postdeploy tasks for package 8c316f6401312ea6f171794ea6acf853d7f2a166
2019-06-19 19:31:07,033 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 8c316f6401312ea6f171794ea6acf853d7f2a166
2019-06-19 19:31:07,181 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for cd398d360d746179da04a19fe608256034f75a64
2019-06-19 19:31:07,232 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 1c0d6bae7a249935add83f80edc2a51a7ee8953d
2019-06-19 19:31:07,293 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 064dcebf3d0e6489859d0f4fb58542b83a861a4b
2019-06-19 19:31:07,354 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for ff801e23a542496dde268f3ed8fe35e1127d8a98
2019-06-19 19:31:07,406 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for e310e6a411f6304052be63c519951937834bcc91
2019-06-19 19:31:07,455 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Begin perform postdeploy tasks for package ef6bc9523775e8a04db11fb489207468d9f450b4
2019-06-19 19:31:07,457 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "1c0d6bae7a249935add83f80edc2a51a7ee8953d" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:31:07,507 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "064dcebf3d0e6489859d0f4fb58542b83a861a4b" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:31:07,525 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "ff801e23a542496dde268f3ed8fe35e1127d8a98" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:31:07,562 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Linking package "e310e6a411f6304052be63c519951937834bcc91" in to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc
2019-06-19 19:31:07,596 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc\streamingsession.json
2019-06-19 19:31:07,625 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - WARNING :: Special action "1b8bf93ad5284c2992ff06d2942d6952" was not in registry
2019-06-19 19:31:07,625 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Complete perform postdeploy tasks for package ef6bc9523775e8a04db11fb489207468d9f450b4
2019-06-19 19:31:07,625 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for ef6bc9523775e8a04db11fb489207468d9f450b4
2019-06-19 19:31:07,715 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Begin perform predeploy tasks for package 068139681db8debdd88176e4058de5b6b8925254
2019-06-19 19:31:08,024 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {CD2A85EC-C80D-4CAC-01C1-FCCDE4A651C8}. Msiexec returns 1605
2019-06-19 19:31:08,170 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {0188C9F4-CCDE-41E9-0150-6B1CFC6AC596}. Msiexec returns 1605
2019-06-19 19:31:08,170 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Complete perform predeploy tasks for package 068139681db8debdd88176e4058de5b6b8925254
2019-06-19 19:31:08,171 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 068139681db8debdd88176e4058de5b6b8925254
2019-06-19 19:31:08,488 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Recording files in registry for 689031f6e7d02c8b3dc7f5cf3f76d213aa641ef9
2019-06-19 19:31:08,549 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Begin perform postdeploy tasks for package 5050e42a9a2dc6e76931bcf98ba255e2b80ba2cb
2019-06-19 19:31:08,565 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - WARNING :: Special action "e11b50c4e45d49c68aa944c2e476a76f" was not in registry
2019-06-19 19:31:08,568 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc\streamingsession.json
2019-06-19 19:31:08,660 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Activating configuration file at \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc\Applications\Fusion\Fusion360App\ApplicationOptions.production.xml as \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc\Fusion 360.server.config
2019-06-19 19:31:08,661 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: But first deleting pre-existing target
2019-06-19 19:31:08,702 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2019-06-19 19:31:08,702 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2019-06-19 19:31:10,486 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json is c259413be1118d48db89f9a325064574:1560557018
2019-06-19 19:31:10,486 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json' to option 'StreamerRootUrl'
2019-06-19 19:31:10,487 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.utils - INFO :: Write value 'c259413be1118d48db89f9a325064574:1560557018' to option 'ETag'
2019-06-19 19:31:10,487 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2019-06-19 19:31:10,572 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2019-06-19 19:31:13,400 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Streamer folder "C:\Users\santo\AppData\Local\Autodesk\webdeploy\meta\streamer\20190226171444" is found
2019-06-19 19:31:13,401 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - INFO :: Find the latest streamer executable "C:\Users\santo\AppData\Local\Autodesk\webdeploy\meta\streamer\20190226171444\streamer.exe"
2019-06-19 19:31:13,457 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.windows.platform - INFO :: Creating uninstall registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2019-06-19 19:31:13,669 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.platform - INFO :: Executing: "\\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\0b5dbc3659d50d942194174a776e4172a7ae70fc\NLauncherConfigurer.exe" "Forge" "Fusion360.exe"
2019-06-19 19:31:16,756 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\santo\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2019-06-19 19:31:16,847 - MainProcess(14656) - Thread-1 - adsk.dls.streamer.process - WARNING :: Exception processing tasks for 5050e42a9a2dc6e76931bcf98ba255e2b80ba2cb: (-2147024894, 'The system cannot find the file specified.', (None, None, None, 0, None))
2019-06-19 19:31:16,911 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2019-06-19 19:31:16,925 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MTg0LjI4LjE3OS4yOA==
2019-06-19 19:31:16,926 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjE0MQ==
2019-06-19 19:31:17,223 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Local DNS: U2VydmVyOiAgbnNjMS5hci5lZC5zaGF3Y2FibGUubmV0DSwgQWRkcmVzczogIDIwMDE6NGU4OjA6NDAwNDo6MTEN
2019-06-19 19:31:32,334 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Network Speed: host: edmonton.speedtest.telus.com:8080, ping: 76.477s, download: 25.451262625727527Mbps
2019-06-19 19:31:32,334 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2019-06-19 19:31:32,334 - MainProcess(14656) - InstallDriver - adsk.dls.streamer.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\process.py", line 1507, in execute
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\process.py", line 1453, in execute_without_errorhandling
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\process.py", line 1211, in _config_app
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\process.py", line 2196, in _do_installation
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\process.py", line 1963, in wait_threads
File "C:\3P\PYTHON\3.5.3c\win64_sp\lib\concurrent\futures\thread.py", line 55, in run
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\process.py", line 2082, in execute_tasks
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\process.py", line 743, in _executetasks
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\windows\platform.py", line 279, in create_launch_items
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\windows\platform.py", line 360, in _manipulate_shortcuts
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\manifests.py", line 764, in walk_external_references
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\windows\platform.py", line 353, in __filevisitor
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\windows\platform.py", line 234, in _create_shortcut
File "R:\Core\Neutron\Installer\Streamer\src\adsk\dls\streamer\windows\native.py", line 161, in Save
_ctypes.COMError: (-2147024894, 'The system cannot find the file specified.', (None, None, None, 0, None))
