Can´t Import .stp lines
emanuel_reit
emanuel_reit
Community Visitor
Community Visitor
Hello Support Team,
i made this plan with a collegue of me on his Inventor and want to import it in Fusion 360 to work on it. My Problem ist, that the lines get lost when i open it in Fusion 360. What can i do? Is it better to use another file format?
In Autodesk Viewer all lines are visible. https://autode.sk/3I1xtGR
Greetings Emanuel
HughesTooling
Fusion can only import curves from DWG or DXF files.
Mark
Mark Hughes
Owner, Hughes Tooling
g-andresen
If you have a solid you can project it into a sketch and then add lines.
günther
