Can't even report a Fusion 360 Bug without a product support subscription
Here is why Fusion 360 stinks: You can't even submit a bug report unless you have a paid subscription. I'm finding that when creating or editing a sketch in Fusion 360, that if I add a text box, when I set the text height to below 8mm, the text just disappears. And then it is no longer available for extrusion in subsequent workflow steps. Thsi is true regardless of font. 3 months ago this did not happen. So now when I go back to edit a design just to change the text, I can't. The text isn't there to edit. Creating a new textbox in an attempt to re-design is also uselss. I don't want replies to this post. This is just a post that I've had it after trying Fusion 360 for a year. Time to move on to something that is much more intuitive, and that just works, and that doesn't have the enormous learning curve. I'm just trying to extrude text on a simple object. This shouldn't be difficult. Bye, Autodesk! I'm leaving you in the 20th century where you belong.
