Can't enter data
Can't enter data
colin_bernard
Can't enter data
colin_bernard
In addition to the problem of opening projects from the browser than many have reported, I have found that I cannot enter data. For example if I try to add a new component, I get the default 'Componentxx' name and when I tried to overwrite the name the field seems to be protected - clicking in it briefly gets the whole name selected then the highlighting disappears and you are forced to leave the field.
Trying to change the name once the component is created you have the same problem when trying to change it directly or via properties.
Similarly trying to enter dimensions I have the same problem so Fusion is unusable at the moment.
Any ideas?
(For info I am using the hobbyist version of Fusion)
AnotherDimension
I'm having the same problem - I can't edit any dimensions.
pannonrider3
had the same problem, restarting fixed it
colin_bernard
Restarting wasn't doing anything for me when I posted the issue but have just tried again and all problems seem to have been sorted.
