Can't Create Sheet metal with flange tool
djstassen84
djstassen84
Good day. I have created a new Component with a new sketch inside of the component. Now when I try to use the flange tool to create a sheet metal, the Flange Toolbox has greyed out the OK button. Please can someone assist me with this problem. I have attached a screenshot of the sketch I would like to use.
jhackney1972
You need to attach your model.  Open design, select the File menu, then Export and save to your hard drive.  Attach file to a reply post.
John Hackney, Retired
djstassen84
Sorry for not attaching the file. But here it is.
jhackney1972
The Flange tool works like a charm for me.  I would suggest you try again AFTER closing Fusion and restarting it again.  If it still will not work, then maybe you need to use the Fusion Service Utility to Repair you application.
