Can't Change to editable between laptop and desktop sessions
markecrum
Observer Observer
markecrum
Observer
Observer
When I work on a document on my laptop and save and exit.... Then I try to use my desktop to open the project it is set to read only. I have made the editable documents under the limit but Fusion will not let me switch the desired doc to editable.... How do I get around this... by the way, it is the same when I draw from the desk top and then try to work on it with the laptop later.
dsouzasujay
Hi @markecrum,
Can you please confirm if both the fusion builds are of same version?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
